Still uploading images after 12 hours?
I’ve added the Lightning Network processing node and started a new project/task. After 12 hours the task status is still ‘uploading images’ 192no. @ 7mb each. Somehow this doesn’t seem right to me? I’m running WebODM using Chrome on Windows 10 with Docker with a cable upload speed of 6mb/s
Same issue here. I’ve just started using webODM and successfully ran a couple of small photo sets both 2d and 3d but as my PC only has 16GB of RAM total I thought I would investigate Lightning for larger jobs.
I have had no success in getting past “uploading images to processing node” despite sending over 100GB of data (for a 7GB photo set) across my internet link.
I’ve tried reducing the number of images and changing the options but it always does the same thing. After the local images upload my PC spends hours sending data to spark1.webodm.net with no movement on the progress bar.
Running WebODM under windows 10 Pro
From processing node info:
WebODM version 0.4.1
API version 1.4.0
(local and lightning nodes are the same)
Server: Docker Engine - Community
Engine:
Version: 18.09.2
API version: 1.39 (minimum version 1.12)
Go version: go1.10.6
Git commit: 6247962
Built: Sun Feb 10 04:13:06 2019
OS/Arch: linux/amd64
Experimental: false
I also have the same issue (both lightning node and local). Just hangs on the “uploading images to processing node”.
A post was split to a new topic: Uploading images to processing node not completing
