Still struggling - new to ODM
I am really working at getting a usable output from ODM or WebODM. I purchased credits to try and stitch 750 drone images together from a DJI Phantom 4 and went through the suggested settings.
Things looked pretty bad.
I can code and use command line well enough so I am trying Docker with odm and it is bombing out. I would like to get a good stitched 2 mile section of a highway.
Does anyone have a success story or any advice or can you point me to an instruction manual for ODM with Windows 10?
My initial cmd line:
docker run -ti --rm -v D:/I89/ICE:/datasets/code opendronemap/odm --project-path D:/I89/ICE/project
Unable to find image ‘opendronemap/odm:latest’ locally
latest: Pulling from opendronemap/odm
281a73dee007: Pull complete 2aea1b77cff7: Pull complete 59a714b7d8bf: Pull complete 0218064da0a9: Pull complete ebac621dcea3: Pull complete a3ed95caeb02: Pull complete b580731643cc: Pull complete faa5fbdba239: Pull complete 28f5ac189537: Pull complete Digest: sha256:7d7ec06832c3d9fdba1ba1ab00e36d3b9082c49fdf3648c65d1c4007193ab2df
Status: Downloaded newer image for opendronemap/odm:latest
[INFO] Initializing OpenDroneMap app - Thu Sep 05 18:02:09 2019
[INFO] ==============
[INFO] build_overviews: False
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] force_gps: False
[INFO] gcp: None
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] max_concurrency: 2
[INFO] merge: all
[INFO] mesh_octree_depth: 9
[INFO] mesh_point_weight: 4
[INFO] mesh_samples: 1.0
[INFO] mesh_size: 100000
[INFO] min_num_features: 8000
[INFO] mve_confidence: 0.6
[INFO] name: code
[INFO] orthophoto_bigtiff: IF_SAFER
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] project_path: D:/I75/ICE/project
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[WARNING] Directory code does not exist. Creating it now.
[INFO] Running dataset stage
[ERROR] Not enough supported images in /code/D:/I75/ICE/project/code/images
Try replacing --project-path argument D:/I89/ICE/project with /datasets as documented on https://docs.opendronemap.org/using.html#docker
