following on this subject a user recently signal me an issue and it seems the fix is no longer working properly.
I have isolated the issue so far in the package onnxruntime as ort
(I suppose that it has been hadded since the precedent fix ?). When there is a non ascci character or accentuated character in the install path of ODM the console will display the following at launch :
2 0 2 2 - 1 2 - 0 7 1 0 : 0 6 : 1 4 . 8 6 0 2 7 8 1 [ W : o n n x r u n t i m e : D e f a u l t , o n n x r u n t i m e _ p y b i n d _ s t a t e . c c : 1 6 2 2 o n n x r u n t i m e : : p y t h o n : : C r e a t e I n f e r e n c e P y b i n d S t a t e M o d u l e ] I n i t p r o v i d e r b r i d g e f a i l e d .
And when running a dataset it fail immediatly with the following callstack trace :
File "C:\testé\ODM\\run.py", line 71, in <module>
retcode = app.execute()
File "C:\testé\ODM\stages\odm_app.py", line 121, in execute
raise e
File "C:\testé\ODM\stages\odm_app.py", line 85, in execute
File "C:\testé\ODM\opendm\types.py", line 382, in run
File "C:\testé\ODM\opendm\types.py", line 361, in run
File "C:\testé\ODM\stages\run_opensfm.py", line 35, in process
File "C:\testé\ODM\opendm\osfm.py", line 395, in feature_matching
self.run('detect_features')
File "C:\testé\ODM\opendm\osfm.py", line 34, in run
system.run('"%s" %s "%s"' %
File "C:\testé\ODM\opendm\system.py", line 94, in run
for line in io.TextIOWrapper(p.stdout):
File "codecs.py", line 322, in decode
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe9 in position 10: invalid continuation byte
Furthermore pdal has improve its handling of utf8 on windows computer according to the changelog, so it could be a bonus to update pdal at least to 2.4.1 ?
I will open a bug on github for the first point but have no clue/idea of how to fix it this time :(.
