I have often difficulties starting up WebODM. I get the following error message:
ERROR: for node-odm-1 Cannot start service node-odm-1: driver failed programming external connectivity on endpoint node-odm-1 (65d59f3b3e519aa6b703252e576f53337be6d2185d877388a725258a519d7c23): Error starting userland proxy: mkdir /port/tcp:0.0.0.0:32779:tcp:172.18.0.2:3000: input/output error
ERROR: for db Cannot start service db: driver failed programming external connectivity on endpoint db (018f55eb0e7a9eb946cb29a17e75112636f155264b1a27a039ebfa2765f4d9af): Error starting userland proxy: mkdir /port/tcp:0.0.0.0:32789:tcp:172.18.0.4:5432: input/output error
E:\programma’s\WebODM Manager\WebODM>exit 0
WebODM has started. You can close this window now. WebODM will continue running.
When I reinstall WebODM it works again, but when I shutdown the computer and restart, the program fails to launch.
If you press “Update” does it start without reinstalling?
