Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
Starting node-odm … failed
Starting db … done
Starting broker … done
Starting worker … done
Starting webapp … done
What I am doing wrong here? Any help would be appreciated?
Thanks!
