Hi, i have this problem to start WebODM
$ ./webodm.sh empezar
Comprobando docker … OK
Comprobando git … OK
Comprobando docker-compose … OK
Iniciando WebODM …
Utilizando el siguiente entorno:
Host: localhost
Puerto: 8000
Directorio de medios: appmedia
SSL: NO
Clave SSL:
certificado SSL:
redirección de puerto inseguro SSL: 80
Celery Broker: redis: // broker
Nodos predeterminados: 1
Asegúrese de emitir un ./webodm.sh si decide cambiar el entorno.
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml start || docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up --scale node-odm = 1
Iniciando nodo-odm … fallido
Iniciando db … fallido
Iniciando corredor … fallido
Iniciando trabajador … fallido
Iniciando aplicación web … fallido
No hay contenedores para comenzar a
extraer db (opendronemap / webodm_db:) …
último: extracción de opendronemap / webodm_db
Any idea? help me please
first type in command line
sudo gpasswd -a $USER docker
secondly run
sudo ./webodm.sh start
which system you are running?
and which command is no found?
more info please
I am whit Windows 10 pro, now not appear “starting … failed” but the instalation stop in “starting … done”
[email protected] MINGW64 /c/WebODM (master)
$ ./webodm.sh start
Checking for docker… OK
Checking for git… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
Starting db … done
Starting node-odm … done
Starting broker … done
Starting worker … done
Starting webapp … done
