Standalone NodeODM Native Windows - GPU Default?
Looking at the thread NodeODM on Windows and it has instructions for starting just the NodeODM instance from a native Windows installation. That is working but can’t seem to figure out if it is making use of the GPU or not. Will that command as issued bring in GPU support (Multiple installations coordinated via ClusterODM) or do I need additional commandline options? Thanks!
Native ODM (and NodeODM) on Windows will always try to make use of the GPU (unless you pass --no-gpu as a task processing option). :clinking_glasses:
Perfect, thanks!
