SSL Install Problems
Hey all –
Hope everyone is having a great weekend.
When installing a new version of WebODM on GCE, I ran into a few errors with implementing SSL.
First, the autogeneration of certificates no longer works. The command in letsencrypt-autogen.sh includes --tls-sni-01, which is deprecated here: https://community.letsencrypt.org/t/how-to-stop-using-tls-sni-01-with-certbot/83210
When using the default --ssl flag, WebODM is then inaccessible.
I generated the keys myself with Certbot and passed them through to WebODM, only to run into another port allocation problem. On restart, WebODM allocates port 80 to a default nginx install, so the rest of the startup fails.
Port 80 screenshot
Here’s what STDOUT looks like.
Will enable SSL (Manual)
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml -f docker-compose.ssl.yml -f docker-compose.ssl-m
anual.yml start || docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml -f docker-compose.ssl.yml -f d
ocker-compose.ssl-manual.yml up --scale node-odm=1
Starting db       ... done
Starting node-odm ... done
Starting broker   ... done
Starting worker   ... done
Starting webapp   ... done
ERROR: No containers to start
Creating network "webodm_default" with the default driver
Creating db ...
Creating webodm_node-odm_1 ...
Creating broker ...
Creating db
Creating broker
Creating broker ... done
Creating worker ...
Creating worker ... done
Creating webapp ...
Creating webapp ... error
ERROR: for webapp  Cannot start service webapp: driver failed programming external connectivity on endpoint webapp (
c40d60930f1a6dd39b78d181681188803ff7a21b7d0e98cf3d3861d5cfb06147): Error starting userland proxy: listen tcp 0.0.0.0
:80: bind: address already in use
The only solution I’ve found is to pass a different SSL_INSECURE_PORT_REDIRECT. Then, WebODM works on port 443.
What might the solution be here?
Thanks again.
Hey @rshea :hand: perhaps this is a bug that needs to be fixed.
Could you open an issue on https://github.com/OpenDroneMap/WebODM/issues referencing this thread?
@pierotofy not a problem.
