I have used the split-merge to handle dataset with large amount of images and it worked well. However, the current flow is to do SfM reconstruction for each submodel, and then subsequent processes, like MVS and meshing, are implemented. May I know the possibility to change the workflow so that MVS and meshing can be proceeded right after the SfM reconstruction in each submodel? In this way, I can examine whether the flight path recovered is acceptable or not immediately. Could you please give me some tips to do it like changing the codes in odd_app.py? Thank you.
