Split Merge
When processing complete dataset sequentially we can stop at some stage we want using end_with parameter. I had a query if it is possible to stop at a stage when using split merge pipeline and running the odm pipeline on each submodel. Can anyone help
Hmm… Interesting use-case.
Why do you want to work like this?
i was getting a error in computing orthophoto cutline and i don’t require the orthophoto stage. my requirement is only till dem stage and i don’t get any error till that
I had mentioned the error here
I cannot understand why the error is occuring
