My latest attempt has 354 images, and I want to avoid paying $160/mo to DigitalOcean to grind through the dataset so I thought I’d test split/merge. I used a split argument of 100, and the (less expensive) cloud instance handled it well enough (under seven hours) but when I downloaded the all.zip, the report directory only contained shots.geojson – not the PDF that I had been hoping to see. Is this a known issue? Thanks!
This is promising! I definitely like the idea of reporting submodel stats, if only to allow folks to tinker with different split sizes and coverages to see which works best.
Thanks for the swift response!
