I have processed one dataset of photos taken by a tablet.
I am using WebODM and I have noticed that the point cloud I get with ODM 2.8.6 is sparser than the one I got with previous versions using the same processing parameters:
Update: I tried with pc-sample=0 and the results are quite similar to the older ones. Could be the pc-sample unit of measure that have been changed in the last version of ODM?
I don’t think we have changed pc-sample behavior in newer releases, but perhaps something did get fixed and now pc-sampling is actually working properly. (0.03 means you’ll get a point every ~3cm).
Thank you pierotofy. In fact I measured the distance and I got 1 mm for the old point cloud and 35mm for the newer one. So probably it was something in the older version of ODM…
