I’m doing some test with smartphone images, not drone images. I want to scan a street and a playground. Im making this test with an iphone and an android device and the 3D results are very good.
But, I don’t get the results geolocated. The images taken have their GPS information though…
How much precision do the GPS coordinates have in the EXIF data?
My old Samsung S8 only records to the nearest arc second, ie about 30 metres, so it is essentially useless for most of the areas I’m likely to be imaging with the phone.
The good news is that the altitude, longitude and latitude appear to be recorded with nanometre precision, although I’m pretty sure the last 12 digits are a bit dodgy
I’m downloading the images now and will see if the geolocation works for me.
Images of water surfaces are always pretty difficult due to lack of features- in this case the water is crystal clear, but refraction changes the relative positions of the rock paving on the bottom when photographed from different positions. This makes feature matching difficult.
Some of the images have strong reflections that hide the bottom of the pool, so it would be better to use a polarising filter.
Also, shading the lens to stop direct sunlight hitting the lens would stop those internal reflections, which are visible on a number of images.
