First time using ODM and I am unable to put together an orthomosaic of very small size.
I select my 23 images, Choose ‘Auto’ for processing node, Options as ‘fast orthophoto’, Resize Images as ‘Yes’ 2048px. Then click review and start processing.
The images upload and resize fine, but shortly after it says it is running, it reports: ‘Process exited with code 1’. Here is the debug output:
[INFO] Fast orthophoto is turned on, automatically setting --skip-3dmodel
[INFO] Initializing ODM - Tue Dec 29 21:07:26 2020
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: True
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 8
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: 5b99a6c5-b810-490e-bda6-fd804bbdd8d1
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: [‘odm_orthophoto’, ‘odm_report’]
[INFO] resize_to: 2048
[INFO] skip_3dmodel: True
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/5b99a6c5-b810-490e-bda6-fd804bbdd8d1/images
[INFO] Loading images database: /var/www/data/5b99a6c5-b810-490e-bda6-fd804bbdd8d1/images.json
[INFO] Found 23 usable images
[INFO] Coordinates file already exist: /var/www/data/5b99a6c5-b810-490e-bda6-fd804bbdd8d1/odm_georeferencing/coords.txt
[INFO] Parsing SRS header: WGS84 UTM 12N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[WARNING] /var/www/data/5b99a6c5-b810-490e-bda6-fd804bbdd8d1/opensfm/image_list.txt already exists, not rerunning OpenSfM setup
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm detect_features “/var/www/data/5b99a6c5-b810-490e-bda6-fd804bbdd8d1/opensfm”
2020-12-29 21:07:26,709 INFO: Extracting ROOT_SIFT features for image DJI_0012.JPG
2020-12-29 21:07:26,710 INFO: Extracting ROOT_SIFT features for image DJI_0011.JPG
2020-12-29 21:07:26,710 INFO: Extracting ROOT_SIFT features for image DJI_0029.JPG
2020-12-29 21:07:26,710 INFO: Extracting ROOT_SIFT features for image DJI_0021.JPG
2020-12-29 21:07:26,710 INFO: Extracting ROOT_SIFT features for image DJI_0018.JPG
2020-12-29 21:07:26,710 INFO: Extracting ROOT_SIFT features for image DJI_0008.JPG
2020-12-29 21:07:26,710 INFO: Extracting ROOT_SIFT features for image DJI_0026.JPG
2020-12-29 21:07:27,059 DEBUG: Computing sift with threshold 0.1
2020-12-29 21:07:27,060 DEBUG: Computing sift with threshold 0.1
2020-12-29 21:07:27,076 DEBUG: Computing sift with threshold 0.1
2020-12-29 21:07:27,078 DEBUG: Computing sift with threshold 0.1
2020-12-29 21:07:27,079 DEBUG: Computing sift with threshold 0.1
2020-12-29 21:07:27,088 DEBUG: Computing sift with threshold 0.1
2020-12-29 21:07:27,098 DEBUG: Computing sift with threshold 0.1
2020-12-29 21:07:27,100 DEBUG: Computing sift with threshold 0.1
/code/SuperBuild/src/opensfm/bin/opensfm: line 12: 152 Killed “$PYTHON” “$DIR”/opensfm_main.py “$@”
app.execute()
File “/code/opendm/types.py”, line 361, in run
File “/code/opendm/types.py”, line 342, in run
File “/code/stages/run_opensfm.py”, line 32, in process
File “/code/opendm/osfm.py”, line 276, in feature_matching
self.run(‘detect_features’)
File “/code/opendm/osfm.py”, line 25, in run
system.run(’%s/bin/opensfm %s “%s”’ %
Exception: Child returned 137
I have a laptop that meets the hardware requirements listed here and I’m running linux.
According to other issues on this forum, I believe this could be an out of memory situation. But in Linux, as far as I can tell, there is no way to add more RAM to a particular container. It just uses what it needs. I’m somewhat experienced with Docker and I’ve never heard of a way to increase a containers memory - but I would love to be told otherwise, it that’s the case.
My hardware specs are modern CPU with 8 cores, 8 GB RAM + swap (4-8 GB, can’t remember) and 500GB SSD.
Thanks for the help!
