Sharing from Windows version
I see the Share button is gone in the Windows version.
What happened ?
And can this be installed in AWS or Google hosting ?
It doesn’t make sense to have a “share” button, because the Windows application is meant to work as a Desktop application (not a server). Exposing the underlying server process to the outside would allow others to log-in and delete your projects (since there’s no login).
Yes this can be installed on AWS or Google.
hello pierotofy I just purchase the webODM installer for windows and I just start using it, what can I do to share the projects with the clients. I will have to install it manually in a server or there is something I can do now that I have it in windows? If not what will be the best solution
thanks
I’d recommend to check out dronedb.app for data sharing. See also Find a way to share URLs via WebODM desktop version · Issue #1002 · OpenDroneMap/WebODM · GitHub
