Is there only the way to share task by click the share button?
I hope that I can enable share task when I call create task API or call a enable share task API.
How do you mean share the task?
The share feature in the view map or 3D model like bellowing picture
It is disable by default, I need to click share button manually to enable share feature.
I use API to call task start, and I hope that I can enable the share feature by API too.
