Securing ClusterODM
What’s the best way to secure a ClusterODM instance? With NodeODM, we can use --token, but ClusterODM doesn’t forward that portion of the API.
I can, of course, put WebODM in front of it, and this secures it nicely, but then I can’t use it with PyODM or CloudODM. I could just use the tutorial at WebODM.org as well.
You could create or modify LocalCloudProvider to check for a particular token:
Admittedly this was part of the original design of LocalCloudProvider, but didn’t get around to implement a --token command line option. Would be a cool PR addition!
I’ve made all of the requests like telnet restricted to my AWS security group. Additionally, I run clusterODM out of webODM and connect to the linux box running webODM using putty tunneling with VNC.
