Scene_dense_dense_filtered.ply file is generated with 'has_views': False
We have generated DepthMaps & Scene_dense_dense_filtered.ply using “DensifyPointCloud” binary from cdcseacave/openMVS instead of OpenDroneMap/openMVS.
And, we notice in next while computing odm_filterpoints stage - ‘has_views’ is set to False and “views=uchar” is not parsed while splitting point cloud.
And eventually, the odm_georeferencing stage fails with the following error:
[INFO] Georeferencing point cloud
[INFO] running pdal translate -i “/datasets/project/odm_filterpoints/point_cloud.ply” -o “/datasets/project/odm_georeferencing/odm_georeferenced_model.laz” ferry transformation --filteerry.dimensions=“views => UserData” --writers.las.compression=“lazip” --filters.transformation.matrix=“1 0 0 602342.0 0 1 0 5765840.0 0 0 1 0 0 0 0 1” --writers.las.offset_x=602342.0 --wrs.las.offset_y=5765840.0 --writers.las.offset_z=0 --writers.las.a_srs=“+proj=utm +zone=31 +datum=WGS84 +units=m +no_defs +type=crs”
PDAL: filters.ferry: Can’t ferry dimension ‘views’. Dimension doesn’t exist.
Can you please suggest, how to parse “has_views” value if this stage is executed using cdcseacave/openMVS instead of OpenDroneMap/openMVS repo?
We carry a number of patches in our fork… Have you looked to see when we added that functionality? You may have to patch the upstream code.
