I’m new to WebODM and running it on Windows 10. I’ve successfully generated the map from the set of 61 images (300Mb in total). I’ve generated the contour file (in .dxf format). The problem I’m having is the scaling issues with the generated contour file when I import it into the AutoCAD. Below I’ve attached the image of the path measurement of the map in WebODM and AutoCAD. Can anyone help me to to figure out this problem?
Path Distance in WebODM - 245m (Left) and Path Distance in AutoCAD shows only 0.0022m (Right)
