Scaling issues in autocad
when i export to autocad as .dxf file, everything works fine however the file is way out of scale within autocad and appears much much smaller than true to life size. is there something i am doing incorrect or is there something i should be doing to prevent this issue. Thanking you in advance.
WebODM Manager Version: 1.9.0.0
Console log:
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Initializing console…
OpenSSH check passed
SET DOCKER_TLS_VERIFY=1
SET DOCKER_HOST=tcp://192.168.99.102:2376
SET DOCKER_CERT_PATH=C:\docker-webodm\machines\webodm
SET DOCKER_MACHINE_NAME=webodm
SET COMPOSE_CONVERT_WINDOWS_PATHS=true
REM Run this command to configure your shell:
REM @FOR /f “tokens=*” %i IN (‘docker-machine --storage-path C:\docker-webodm env webodm’) DO @%i
Setup env variable: DOCKER_TLS_VERIFY=1
Setup env variable: DOCKER_HOST=tcp://192.168.99.102:2376
Setup env variable: DOCKER_CERT_PATH=C:\docker-webodm\machines\webodm
Setup env variable: DOCKER_MACHINE_NAME=webodm
Setup env variable: COMPOSE_CONVERT_WINDOWS_PATHS=true
Setup env variable: COMPOSE_TLS_VERSION=TLSv1_2
Client:
Version: 18.09.3
API version: 1.39
Go version: go1.12
Git commit: 774a1f4eee
Built: Mon Mar 4 10:36:44 2019
OS/Arch: windows/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 19.03.12
API version: 1.40 (minimum version 1.12)
Go version: go1.13.10
Git commit: 48a66213fe
Built: Mon Jun 22 15:49:35 2020
OS/Arch: linux/amd64
Experimental: false
containerd:
Version: v1.2.13
GitCommit: 7ad184331fa3e55e52b890ea95e65ba581ae3429
runc:
Version: 1.0.0-rc10
GitCommit: dc9208a3303feef5b3839f4323d9beb36df0a9dd
docker-init:
Version: 0.18.0
GitCommit: fec3683
Press Start WebODM to launch
192.168.99.102
You can now access WebODM :slight_smile:
Settings:
Driver: virtualbox
Storage path: C:\docker-webodm
Use Hyper-V: no
Windows version: 10.0.17134.0
Windows build: 17134
Product type: 101
Product name: Windows 10 Home
Is Windows 10 Home: yes
System info:
Host Name: DESKTOP-QCRD62A
OS Name: Microsoft Windows 10 Home
OS Version: 10.0.17134 N/A Build 17134
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: Windows User
Registered Organization:
Product ID: 00326-00809-96163-AAOEM
Original Install Date: 9/11/2018, 4:09:23 PM
System Boot Time: 2/02/2021, 6:33:16 PM
System Manufacturer: Micro-Star International Co., Ltd.
System Model: MS-7A39
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: AMD64 Family 23 Model 1 Stepping 1 AuthenticAMD ~3200 Mhz
BIOS Version: American Megatrends Inc. 2.H0, 10/07/2018
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Boot Device: \Device\HarddiskVolume2
System Locale: en-gb;English (United Kingdom)
Input Locale: en-us;English (United States)
Time Zone: (UTC+10:00) Brisbane
Total Physical Memory: 32,719 MB
Available Physical Memory: 8,919 MB
Virtual Memory: Max Size: 55,247 MB
Virtual Memory: Available: 24,998 MB
Virtual Memory: In Use: 30,249 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: \DESKTOP-QCRD62A
Hotfix(s): 10 Hotfix(s) Installed.
[01]: KB4230204
[02]: KB4346084
[03]: KB4456655
[04]: KB4465663
[05]: KB4477137
[06]: KB4485449
[07]: KB4497398
[08]: KB4503308
[09]: KB4509094
[10]: KB4507466
Network Card(s): 4 NIC(s) Installed.
[01]: Realtek PCIe GBE Family Controller
Connection Name: Ethernet
Status: Media disconnected
[02]: Qualcomm Atheros AR9287 Wireless Network Adapter
Connection Name: WiFi
DHCP Enabled: Yes
DHCP Server: 192.168.1.1
IP address(es)
[01]: 192.168.1.7
[02]: fe80::3920:2528:cb12:b823
[03]: fd94:fe22:c0b:cf00:a528:7226:268d:fb8
[04]: fd94:fe22:c0b:cf00:8d9c:a2de:9c00:d7f7
[05]: fd94:fe22:c0b:cf00:191d:a1b:2ddd:6c65
[06]: fd94:fe22:c0b:cf00:3920:2528:cb12:b823
[03]: VirtualBox Host-Only Ethernet Adapter
Connection Name: VirtualBox Host-Only Network
DHCP Enabled: No
IP address(es)
[01]: 192.168.56.1
[02]: fe80::65fd:7f1d:e726:4c0f
[04]: VirtualBox Host-Only Ethernet Adapter
Connection Name: VirtualBox Host-Only Network #2
DHCP Enabled: No
IP address(es)
[01]: 192.168.99.1
[02]: fe80::c4f:c149:351b:4330
Virtualization Enabled In Firmware: Yes
Second Level Address Translation: Yes
Data Execution Prevention Available: Yes
Possibly related: Scaling issues with the contour file when imported to AutoCAD from the file generated from WebODM
What are your AutoCAD units? WebODM outputs use meters.
