I am trying to figure out how I can download results from a ODMNode running on a VM in the Azure cloud to a blob in Azure cloud via the python SDK. Is this supported?
Basically, download the result from a node to a url location instead of local dir.
I am trying to do that through a serverless function which might add some complexity.
I understand, I have seen that AWS is mentioned in documentation and in the forum.
As of now I am trying to download it locally via the Function and then upload it to a bucket/blob. Works when I test on my computer but have to see how it works out deployed in the cloud.
#set tmp to variable zip_dir
zip_dir = tempfile.gettempdir()
#download the zip result and save it to variable blob_path
blob_path = task.download_zip(zip_dir)
#create a blob name
blob = "result_" + uuid1+ ".zip"
#finally upload the blob, could be done with output parameter as well.
blob_service.create_blob_from_path(top_level_container_name, blob, blob_path)
