Hallo,
is there a way getting the NodeMicMac integrated as a node in WebODM on M1 using the WebODM Manager?
By the way, the performance so far on the recent 16 inch MBP (Apple M1 Max) is already really pretty impressive!
Cheers
Hallo,
Cheers
You should just be able to issue the following command:
./webodm.sh restart --with-micmac
Thanks!
That’s the command to restart with MicMac in Linux-sourroundings by typing it in the terminal, correct?
Recently, I am trying to add NodeMicMac in the MacOS-version, not knowing where do I have to enter those commands when using the docker-version with the WebODM-Manager there? Is there a possibility?
Thanks in advance!
In the menu of the WebODM Manager (on the Windows version, at least) there is a menu item to enable the NodeMicMac support. I believe the MacOS version has that, as well.
Indeed, there does exist NodeMicMac as an experimental feature as an option in the windows version and its running fine.
Only in the MacOS-version it seems to be missing.
Whereas using the linux version its running seamlessly. By the way, I have been using a virtualized version of Ubuntu on a 16 inch M1 and can recommend it so no worries!
What version of the WebODM Manager for MacOS do you have? Did you just purchase/download it recently?
Nope, I purchased the WebODM-Manager for MacOS already some time ago in November '21. It’s running Version “1.3”.
Has there been an update in the meanwhile?
Currently the WebODM Manager on Mac does not have the option to enable MicMac.
Thank u a lot for your help and for those fast responses - really appreciate the great work u’re doing - !
