Good night,
Id like to make one question.
Do I need to install ODM and node-odm to run webodm natively?
I did as the guide says (https://github.com/OpenDroneMap/WebODM#run-it-natively). But there is no node online.
Good night,
If you want to process datasets on the same machine, yes, you need to setup ODM and node-ODM as well.
