Hello all! I think I can already come up with the answer to this but figured I would ask anyways. Is it possible to have the native installer running on multiple machines all work on the same project? I have some datasets over 1500-2000 images and have a laptop with 32gb, desktop with 16gb, and a few other machines totaling 26gb together. Wondering if I could take advantage of all 74GB of ram across all machines to work on a large data set. I have tried messing around with this with the docker version but had no success. I think in the end it would be way easier to have 1 machine with more ram, but then things get a little pricey. Thank you all for the help!!
Possible, sure, but you’re going to need to have at least one ClusterODM marshaller for the split/merge job control, and you’re going to need to specify the ClusterODM address with the --sm-cluster option.
