Hi all,
I tried the rolling shutter correction parameter with an Anafi but the resulting orthophoto shows artifacts.
Having a look at the RS repository, I realised that data for the Anafi is not present even if this message seems to provide it :
So I tried with 160ms as readout time but there are still the same kind of artifacts.
I will try to make my own measurements but as anybody successfully applied the rolling shutter correction to some anafi datas ?
Alas it seems globally better but there are still weird artifacts.
I will have a deeper look on Monday and will provide you some screenshots or the reports.
Regarding the report what part/data exactly should I be looking at?
The Z axis looked like it went a bit crazy with the rolling shutter correction, but not doing any correction seems to have given a respectable result. I’d just not bother with the shutter correction as it’s obviously causing issues in this instance.
Thank you for your answer but I would be curious to find what causes this strange behavior.
We are running ODM automatically inside a pipeline here (automatic flight, data transfer, reconstruction, filtering, reprojection and importation). That is why we can not “afford” to look at each dataset and it’s output to decided weather or not we should rerun-it with or without the rolling shutter correction.
If I can’t find a reason I will be forced to “not enable” it for all reconstructions to prevent this case.
Would be a shame I think…
Hiya - I did the flicker test with ANAFI Thermal and ANAFI USA and got 160 ms. My results haven’t been so great applying a shutter correction, so I never updated the database. More work on why is funding-dependent
Strong suspicion: with longer shutter times and certain types of movements, rolling shutter corrections using this approach break down. 160ms is pretty long. I would recommend keeping it off for Anafi.
