I think that rewriting the code base to typescript will make it easier to maintain and understand. Better understanding of the API and integration of the different parts.
This change can be gradual.
Do you have any thoughts on where to begin?
I would say the best start would be to setup existing code as a typescript project.
There is no need initially to change any of the existing code, Maybe only the index.js.
This article explains it very well:
https://khalilstemmler.com/blogs/typescript/node-starter-project/
Then a multistage Dockerfile should be created.
Example:
https://medium.com/@ankit.wal/the-why-and-how-of-multi-stage-docker-build-with-typescript-example-bcadbce2686c
Actual coversion to typescript can be done later and gradually.
Are you in a position to help us out with a draft PR?
Thanks for the documentation, by the way!
It’s a large effort, but we’d welcome contributions for sure!
I’m not free right now. I’ll try to make a draft PR in the next 2 weeks I hope.
PR is ready for review
