Once I load photographs in a “Project”, and say, run a fast Ortho, is it possible to Add a task to That Project, using the pre-loaded photographs that were loaded and reside to the data for the project?
It seems redundant and wasteful of Drive Space to, say, run a “Fast Ortho”, then to want to run a “Default”, 3D, or a higher detailed 3D project, using the same photographs with slightly different tasking.
