The above two images were the results of running ODM on one band and multiple bands. The result obtained using one band were good but when used for multiple bands the image distorted. Any suggestions to improve. Please.
Were the settings exactly the same across both processing runs?
Yes
All the default settings were used
Can you try with --crop 0 and maybe increasing --feature-quality?
okay. Thanks for the input
I will confess that I haven’t done any multispectral work yet, but did you specify your primary band for matching as the same as the band that successfully completes? This appears to be some matching challenges probably associated with matches attempted on a low-contrast band.
This. Make sure you selected the same band.
