I have been unable to process any images successfully into an orthomosaic. Images have been collected with a DJI Matrice 100 using a Zen Muse 3 camera. Have tried using images collected with three mapping programs: DJI GC, Precision Flight, and Drone Deploy. In each instance an error Code 1 is returned. Have tried adjusted the paramaters suggested with no success.
Here is a sample of the errors and warning that occur early in the processing:
Error: Directory Iop: Next pointer is out of bounds; ignored.
Error: Directory (Last IFD item) with 41992 entries considered invalid; not read.
Error: Directory (Last IFD item): Next pointer is out of bounds; ignored.
Error: Upper boundary of data for directory (Last IFD item), entry 0x4a49 is out of bounds: Offset = 0x00000001, size = 65540, exceeds buffer size by 56472 Bytes; truncating the entry
Error: Upper boundary of data for directory (Last IFD item), entry 0x0100 is out of bounds: Offset = 0x000000cd, size = 1441794, exceeds buffer size by 1432930 Bytes; truncating the entry
Warning: Directory (Last IFD item), entry 0xcccc has unknown Exif (TIFF) type 48388; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0xcccc is out of bounds: Offset = 0x00000000; truncating the entry
Warning: Directory (Last IFD item), entry 0x00f0 has unknown Exif (TIFF) type 16389; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x00f0 is out of bounds: Offset = 0x00000000; truncating the entry
Warning: Directory (Last IFD item), entry 0x0080 has unknown Exif (TIFF) type 16134; setting type size 1.
Error: Upper boundary of data for directory (Last IFD item), entry 0x0080 is out of bounds: Offset = 0x0000009a, size = 720897, exceeds buffer size by 711982 Bytes; truncating the entry
Warning: Directory (Last IFD item), entry 0x9901 has unknown Exif (TIFF) type 49415; setting type size 1.
Error: Upper boundary of data for directory (Last IFD item), entry 0x9901 is out of bounds: Offset = 0x00000033, size = 720897, exceeds buffer size by 711879 Bytes; truncating the entry
Warning: Directory (Last IFD item), entry 0x33ae has unknown Exif (TIFF) type 16904; setting type size 1.
Error: Upper boundary of data for directory (Last IFD item), entry 0x33ae is out of bounds: Offset = 0x0000009a, size = 720897, exceeds buffer size by 711982 Bytes; truncating the entry
Warning: Directory (Last IFD item), entry 0x9919 has unknown Exif (TIFF) type 49161; setting type size 1.
Error: Upper boundary of data for directory (Last IFD item), entry 0x9919 is out of bounds: Offset = 0x000000cd, size = 720897, exceeds buffer size by 712033 Bytes; truncating the entry
Warning: Directory (Last IFD item), entry 0xcca0 has unknown Exif (TIFF) type 49674; setting type size 1.
Error: Upper boundary of data for directory (Last IFD item), entry 0xcca0 is out of bounds: Offset = 0x0000009a, size = 720897, exceeds buffer size by 711982 Bytes; truncating the entry
Warning: Directory (Last IFD item), entry 0x99b4 has unknown Exif (TIFF) type 16907; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x99b4 is out of bounds: Offset = 0x00000000; truncating the entry
Warning: Directory (Last IFD item), entry 0x0000 has unknown Exif (TIFF) type 0; setting type size 1.
Warning: Directory (Last IFD item), entry 0x0000 has unknown Exif (TIFF) type 256; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0000 is out of bounds: Offset = 0x00000000; truncating the entry
Warning: Directory (Last IFD item), entry 0x0100 has unknown Exif (TIFF) type 512; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0100 is out of bounds: Offset = 0x00000000; truncating the entry
Warning: Directory (Last IFD item), entry 0x0200 has unknown Exif (TIFF) type 1280; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0200 is out of bounds: Offset = 0x00058500; truncating the entry
Warning: Directory (Last IFD item), entry 0x0300 has unknown Exif (TIFF) type 512; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0300 is out of bounds: Offset = 0x00000000; truncating the entry
Warning: Directory (Last IFD item), entry 0x0400 has unknown Exif (TIFF) type 1280; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0400 is out of bounds: Offset = 0x00059d00; truncating the entry
Warning: Directory (Last IFD item), entry 0x0500 has unknown Exif (TIFF) type 256; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0500 is out of bounds: Offset = 0x00000000; truncating the entry
Warning: Directory (Last IFD item), entry 0x0600 has unknown Exif (TIFF) type 1280; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0600 is out of bounds: Offset = 0x0005b500; truncating the entry
Warning: Directory (Last IFD item), entry 0x0000 has unknown Exif (TIFF) type 9984; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0000 is out of bounds: Offset = 0x00271000; truncating the entry
Warning: Directory (Last IFD item), entry 0x0000 has unknown Exif (TIFF) type 19712; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0000 is out of bounds: Offset = 0x00003a00; truncating the entry
Warning: Directory (Last IFD item), entry 0x039b has unknown Exif (TIFF) type 61952; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x039b is out of bounds: Offset = 0x01000100; truncating the entry
Warning: Directory (Last IFD item), entry 0x0200 has unknown Exif (TIFF) type 0; setting type size 1.
Error: Upper boundary of data for directory (Last IFD item), entry 0x0200 is out of bounds: Offset = 0x00000601, size = 72497464, exceeds buffer size by 72489932 Bytes; truncating the entry
Warning: Directory (Last IFD item), entry 0x0300 has unknown Exif (TIFF) type 768; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0300 is out of bounds: Offset = 0x06000001; truncating the entry
Warning: Directory (Last IFD item), entry 0x1a00 has unknown Exif (TIFF) type 1280; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x1a00 is out of bounds: Offset = 0x00061901; truncating the entry
Warning: Directory (Last IFD item), entry 0x1b00 has unknown Exif (TIFF) type 1280; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x1b00 is out of bounds: Offset = 0x00062101; truncating the entry
Warning: Directory (Last IFD item), entry 0x2800 has unknown Exif (TIFF) type 768; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x2800 is out of bounds: Offset = 0x02000002; truncating the entry
Warning: Directory (Last IFD item), entry 0x0100 has unknown Exif (TIFF) type 1024; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0100 is out of bounds: Offset = 0x00062902; truncating the entry
Warning: Directory (Last IFD item), entry 0x0200 has unknown Exif (TIFF) type 1024; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0200 is out of bounds: Offset = 0x001d4400; truncating the entry
Error: Upper boundary of data for directory (Last IFD item), entry 0x0000 is out of bounds: Offset = 0x00000100, size = 18432, exceeds buffer size by 9619 Bytes; truncating the entry
Warning: Directory (Last IFD item), entry 0x0000 has unknown Exif (TIFF) type 18432; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0000 is out of bounds: Offset = 0xd8ffdb00; truncating the entry
Warning: Directory (Last IFD item), entry 0x8400 has unknown Exif (TIFF) type 1027; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x8400 is out of bounds: Offset = 0x04030303; truncating the entry
Warning: Directory (Last IFD item), entry 0x0404 has unknown Exif (TIFF) type 1029; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0404 is out of bounds: Offset = 0x0505060c; truncating the entry
Warning: Directory (Last IFD item), entry 0x0809 has unknown Exif (TIFF) type 1802; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0809 is out of bounds: Offset = 0x0e0c0d0d; truncating the entry
Warning: Directory (Last IFD item), entry 0x0f11 has unknown Exif (TIFF) type 5651; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0f11 is out of bounds: Offset = 0x0d0d131a; truncating the entry
Warning: Directory (Last IFD item), entry 0x1315 has unknown Exif (TIFF) type 5912; setting type size 1.
Error: Directory (Last IFD item), entry 0x1315 has invalid size 4210752151; skipping entry.
Warning: Directory (Last IFD item), entry 0x181d has unknown Exif (TIFF) type 5656; setting type size 1.
Error: Directory (Last IFD item), entry 0x181d has invalid size 4210035241; skipping entry.
Warning: Directory (Last IFD item), entry 0x060b has unknown Exif (TIFF) type 1542; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x060b is out of bounds: Offset = 0x10181818; truncating the entry
Warning: Directory (Last IFD item), entry 0x1818 has unknown Exif (TIFF) type 6168; setting type size 1.
Error: Directory (Last IFD item), entry 0x1818 has invalid size 4042322161; skipping entry.
Warning: Directory (Last IFD item), entry 0xc000 has unknown Exif (TIFF) type 4360; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0xc000 is out of bounds: Offset = 0x03012100; truncating the entry
Warning: Directory (Last IFD item), entry 0x0211 has unknown Exif (TIFF) type 259; setting type size 1.
Error: Directory (Last IFD item), entry 0x0211 has invalid size 2853436841; skipping entry.
Warning: Directory (Last IFD item), entry 0x0105 has unknown Exif (TIFF) type 257; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0105 is out of bounds: Offset = 0x00000000; truncating the entry
Error: Offset of directory (Last IFD item), entry 0x0000 is out of bounds: Offset = 0x05060708; truncating the entry
Warning: Directory (Last IFD item), entry 0x090a has unknown Exif (TIFF) type 2832; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x090a is out of bounds: Offset = 0x03020403; truncating the entry
Warning: Directory (Last IFD item), entry 0x0505 has unknown Exif (TIFF) type 1028; setting type size 1.
Error: Offset of directory (Last IFD item), entry 0x0505 is out of bounds: Offset = 0x01020300; truncating the entry
Warning: Directory (Last IFD item), entry 0x0411 has unknown Exif (TIFF) type 1298; setting type size 1.
Error: Directory (Last IFD item), entry 0x0411 has invalid size 5568760381; skipping entry.
Warning: Directory (Last IFD item), entry 0x2271 has unknown Exif (TIFF) type 5170; setting type size 1.
Error: Directory (Last IFD item), entry 0x2271 has invalid size 21738048081; skipping entry.
Warning: Directory (Last IFD item), entry 0x1552 has unknown Exif (TIFF) type 53744; setting type size 1.
Error: Directory (Last IFD item), entry 0x1552 has invalid size 6073473141; skipping entry.
Warning: Directory (Last IFD item), entry 0x1718 has unknown Exif (TIFF) type 6426; setting type size 1.
Error: Directory (Last IFD item), entry 0x1718 has invalid size 6232573841; skipping entry.
Warning: Directory (Last IFD item), entry 0x3637 has unknown Exif (TIFF) type 14393; setting type size 1.
Error: Directory (Last IFD item), entry 0x3637 has invalid size 9774869171; skipping entry.
Warning: Directory (Last IFD item), entry 0x4a53 has unknown Exif (TIFF) type 21589; setting type size 1.
Error: Directory (Last IFD item), entry 0x4a53 has invalid size 14485648251; skipping entry.
Warning: Directory (Last IFD item), entry 0x6667 has unknown Exif (TIFF) type 26729; setting type size 1.
Error: Directory (Last IFD item), entry 0x6667 has invalid size 17859513491; skipping entry.
Warning: Directory (Last IFD item), entry 0x7a83 has unknown Exif (TIFF) type 33925; setting typ
