Repeat process on loaded dataset with DIFFERENT parameters
I uploaded a data set through the web interface webodm, and after that, I notice I need to change some parameter. I need to re-run or repeat the process WITHOUT the need to re-load the whole dataset, since it’s huge (3gb).
Is it possible ?
daniele
No, that’s not currently possible. It will re-load all the assets and re-process the data.
