Remote connection from smartphone
I tried setting up my system so I can remotely connect from my phone to a running instance of WebODM, to monitor progress, but I’ve been unsuccessful.
If I connect to localhost:8000 from the system where WebODM is running, everything’s OK.
If I connect to [my computer’s local IP]:8000 from my phone, while connected via wifi to my home network, everything’s OK.
If I try to connect to [my computer’s PUBLIC IP]:8000 from my local PC, everything’s OK.
If I try to connect remotely to [my public IP]:8000 I get no response.
Of course on my router I have set up a port forwarding rule: everything coming from outside on port 8000 gets redirected to my computer’s local IP on port 8000. I have setup both TCP and UDP protocols for forwarding.
Do I need to enable something else? I have setup similar forwarding rules for a couple of Raspberry PI’s, in exactly the same way, and they work well…
My router is a FritzBox 7530.
Could it be that if there is one active connection to WebODM (from my local PC) it won’t accept other connections?
Cristian
If you ping and tracert that, does it reach the WebODM endpoint or does it stop somewhere before then?
I honestly don’t know how to do that on my phone (Android).
But to summarize, after a few more tests:
From my PC:
localhost:8000 → Works
[my local IP]:8000 → Works
[my public IP]:8000 → Works
So all OK.
From my wife’s computer, on the same network as my PC:
localhost:8000 → Fails (expected)
[my PC’s local IP]:8000 → Works
So all OK.
From my phone connected to my WiFi:
[my public IP]:8000 → Times out.
So it’s just from the phone while connecting to my public IP, that I have a problem. So it appears it’s not a WebODM issue. Now, why this happens, I have no idea…
Cristian
EDIT: I was wrong, my wife’s computer can’t connect to WebODM when using my public IP. I don’t know why I thought it worked before.
So, I can only connect using my public IP, if I do it from my own PC, not from my phone or from my wife’s PC.
Are you able to run the tests from your mobile using PortDroid?:
Thank you, I tried PortDroid.
From the phone, remotely connected, I can ping my public IP fine.
I tried a port scan, and apparently all ports are closed except port 80 and two other ports that I use for my raspberrys. I don’t know why only the one I setup for WebODM is closed… I suppose it’s closed not by the server but by the computer itself?
I tried a traceroute yo my public IP, and it followed 7 steps (took quite a long time) and the last step is my public IP. Should I copy the steps here?
No, please don’t post your traceroute :slight_smile: Never a good thing to share to the wider internet.
Alright, it seems at this juncture that you have a firewall in the way, either your home/router firewall, or the one on the machine hosting WebODM. You’ll need to poke around there to see what is happening a bit more.
Thanks. I suppose it’s not the router, because it doesn’t stop the traffic to the raspberrys. I’ll check ubuntu’s firewall rules. Though, I wonder why it works if I connect using my public IP, from my local PC…
EDIT:
I checked, and apparently the default firewall for Ubuntu is ‘ufw’, which is installed but disabled on my system. As far as I know there’s no other firewall on this system, so nothing should be preventing access to port 8000. Could there be something in the way in the linux<->docker interface?
Sorry, I couldn’t find how to insert these images on my previous message, so I’m posting them here.
This is the port forwarding setting of my router:
Router
And the raspberry and home assistant are perfectly reachable from the outside, including my phone.
This is the status output of my computer’s firewall:
firewall
The samba is perfectly accessible from other devices on my home network. And also WebODM is perfectly accessible if I use my local IP, from my phone, if the phone is on my home network.
Only connecting from the outside does not work. Ideas?
By any chance are you trying to this on Firefox Android? For me it works on chrome but completely unresponsive on FF.
I tried on Chrome and on the native OPPO browser. It times out on both.
