This is what I expect, or at least there’s no real surprises. The rectangular angry bit in the north central section is a pond and still water causes wackiness.
It’s the middle of the night for me so forgive me if I’m way off, but it looks like you are comparing the DSM and the DTM, and them being different from one another makes sense.
Do you have them both from prior versions? Or the data to share?
They should be different, but not in this way. For instance, the house and barn are neatly erased from the DTM, but the huge crater is definitely wrong.
Here’s an example (different data but same location) that was processed on April 5th:
This is what I recall seeing all the time previously. I’m going to save all the products from this run and then rerun it with a freshly downloaded container and see what I get. I do not know precisely which settings I used on the original one, so I’ll try ultra/ultra first since that’s what I used for the original post.
I ran another several missions today and then processed the images with my arguments to see if there was something about those pictures, and I’m still seeing the cratering. I’ll do the same with Gordon’s.
Indeed, I am surprised you’re having bad reconstruction in that area. What does your report’s overlap analysis look like? This was a clean dataset. Great work!
