Reducing cloud point size - 3d model
I’m creating buildings 3d models to improve my photovoltaic projects… but the 3d models i’m creating are too big. For example… the WebODM creates a full 3d model, with objects I don’t need as well… for example, streets etc.
Is there a way to reduce the 3d model to only the object I need… example: house in the middle
I’m learning how to use the photogrametry and had no previous experience
For example, I need only the house in that picture… how can I delete the surrouding objects?
Thank you all
Amazing results so far!
Yes, please see our --boundary option we added recently:
https://docs.opendronemap.org/arguments/boundary/
I’ve found http://geojson.io, one of the options in the link posted above, to work well, you can draw your polygons before processing in WebODM, so that you don’t need to edit later.
