Reconstructing all views - 43+ hours
I am exploring workflows for our company to process UAV photos at large construction sites to create orthoimagery, surfaces, and volume measurements. WebODM looks very powerful for what we need. We are currently running a High-Resolution Orthoimagery Task with 403 photos & GCP file and I’m really just curious on how long we might expect similar projects to take. I don’t believe I’ve changed any default parameters. This task is still running after over 43 hours. Based on other forum posts, it seems projects are completing in under 20-30 hours? Specifically, I found this link and other forum posts recommending continuing to wait:
Windows 10 Pro 64-bit, 4.0 GHz, 32GB Memory…
Using WebODM in Chrome, single processing node (default node-odm-1)…
Docker settings are 3 CPU’s, 12800MB Memory, 1536MB Swap, 59.6GM Disk Image Max Size (44.82 BG Used)
Here is a Google Drive link for drone photos and GCP file:
https://drive.google.com/open?id=119R_IBc6KSjR6E-0IwqQqruIaXfssu5I
Thank you very much for any recommendations. I’m still trying to expand my knowledge base with WebODM. Here is the current truncated task output:
… output truncated at 500 lines …
2019-12-31 20:27:24,568 DEBUG: STREAM ‘IHDR’ 16 13
2019-12-31 20:27:24,568 DEBUG: STREAM ‘IDAT’ 41 8192
2019-12-31 20:27:24,569 DEBUG: STREAM ‘IHDR’ 16 13
2019-12-31 20:27:24,569 DEBUG: STREAM ‘IDAT’ 41 8192
2019-12-31 20:27:24,570 DEBUG: STREAM ‘IDAT’ 41 8192
2019-12-31 20:27:24,570 DEBUG: STREAM ‘IHDR’ 16 13
2019-12-31 20:27:24,571 DEBUG: STREAM ‘IDAT’ 41 8192
2019-12-31 20:27:24,571 DEBUG: STREAM ‘IHDR’ 16 13
2019-12-31 20:27:24,572 DEBUG: STREAM ‘IHDR’ 16 13
2019-12-31 20:27:24,572 DEBUG: STREAM ‘IDAT’ 41 8192
2019-12-31 20:27:24,573 DEBUG: STREAM ‘IHDR’ 16 13
2019-12-31 20:27:24,573 DEBUG: STREAM ‘IDAT’ 41 8192
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm export_geocoords --transformation --proj ‘+proj=utm +zone=19 +datum=WGS84 +units=m +no_defs +type=crs’ “/var/www/data/14aa563e-6709-42f0-a29d-2babf722de2d/opensfm”
[INFO] Finished opensfm stage
[INFO] Running mve stage
[INFO] running /code/SuperBuild/src/elibs/mve/apps/makescene/makescene “/var/www/data/14aa563e-6709-42f0-a29d-2babf722de2d/opensfm/reconstruction.nvm” “/var/www/data/14aa563e-6709-42f0-a29d-2babf722de2d/mve”
MVE Makescene (built on Nov 19 2019, 17:32:29)
Info: Detected VisualSFM bundle format.
NVM: Loading file…
NVM: Number of features: 388506
Creating output directories…
Writing MVE views…
Writing MVE view: view_0001.mve…
Writing MVE view: view_0002.mve…
Writing MVE view: view_0000.mve…
Writing MVE view: view_0003.mve…
Writing MVE view: view_0004.mve…
Writing MVE view: view_0005.mve…
Writing MVE view: view_0006.mve…
Writing MVE view: view_0007.mve…
Writing MVE view: view_0008.mve…
Writing MVE view: view_0009.mve…
Writing MVE view: view_0011.mve…
Writing MVE view: view_0010.mve…
Writing MVE view: view_0012.mve…
Writing MVE view: view_0013.mve…
Writing MVE view: view_0014.mve…
Writing MVE view: view_0015.mve…
Writing MVE view: view_0016.mve…
Writing MVE view: view_0017.mve…
Writing MVE view: view_0018.mve…
Writing MVE view: view_0019.mve…
Writing MVE view: view_0020.mve…
Writing MVE view: view_0021.mve…
Writing MVE view: view_0022.mve…
Writing MVE view: view_0023.mve…
Writing MVE view: view_0024.mve…
Writing MVE view: view_0025.mve…
Writing MVE view: view_0026.mve…
Writing MVE view: view_0027.mve…
Writing MVE view: view_0028.mve…
Writing MVE view: view_0029.mve…
Writing MVE view: view_0030.mve…
Writing MVE view: view_0031.mve…
Writing MVE view: view_0032.mve…
Writing MVE view: view_0033.mve…
Writing MVE view: view_0034.mve…
Writing MVE view: view_0035.mve…
Writing MVE view: view_0036.mve…
Writing MVE view: view_0037.mve…
Writing MVE view: view_0038.mve…
Writing MVE view: view_0039.mve…
Writing MVE view: view_0040.mve…
Writing MVE view: view_0041.mve…
Writing MVE view: view_0042.mve…
Writing MVE view: view_0043.mve…
Writing MVE view: view_0044.mve…
Writing MVE view: view_0045.mve…
Writing MVE view: view_0046.mve…
Writing MVE view: view_0047.mve…
Writing MVE view: view_0048.mve…
Writing MVE view: view_0049.mve…
Writing MVE view: view_0050.mve…
Writing MVE view: view_0051.mve…
Writing MVE view: view_0052.mve…
Writing MVE view: view_0053.mve…
Writing MVE view: view_0054.mve…
Writing MVE view: view_0055.mve…
Writing MVE view: view_0056.mve…
Writing MVE view: view_0057.mve…
Writing MVE view: view_0058.mve…
Writing MVE view: view_0059.mve…
Writing MVE view: view_0060.mve…
Writing MVE view: view_0061.mve…
Writing MVE view: view_0062.mve…
Writing MVE view: view_0063.mve…
Writing MVE view: view_0064.mve…
Writing MVE view: view_0065.mve…
Writing MVE view: view_0066.mve…
Writing MVE view: view_0067.mve…
Writing MVE view: view_0068.mve…
Writing MVE view: view_0069.mve…
Writing MVE view: view_0070.mve…
Writing MVE view: view_0071.mve…
Writing MVE view: view_0072.mve…
Writing MVE view: view_0073.mve…
Writing MVE view: view_0074.mve…
Writing MVE view: view_0075.mve…
Writing MVE view: view_0076.mve…
Writing MVE view: view_0077.mve…
Writing MVE view: view_0078.mve…
Writing MVE view: view_0079.mve…
Writing MVE view: view_0080.mve…
Writing MVE view: view_0081.mve…
Writing MVE view: view_0082.mve…
Writing MVE view: view_0083.mve…
Writing MVE view: view_0084.mve…
Writing MVE view: view_0085.mve…
Writing MVE view: view_0086.mve…
Writing MVE view: view_0087.mve…
Writing MVE view: view_0088.mve…
Writing MVE view: view_0089.mve…
Writing MVE view: view_0090.mve…
Writing MVE view: view_0091.mve…
Writing MVE view: view_0092.mve…
Writing MVE view: view_0093.mve…
Writing MVE view: view_0094.mve…
Writing MVE view: view_0095.mve…
Writing MVE view: view_0096.mve…
Writing MVE view: view_0097.mve…
Writing MVE view: view_0098.mve…
Writing MVE view: view_0099.mve…
Writing MVE view: view_0100.mve…
Writing MVE view: view_0101.mve…
Writing MVE view: view_0102.mve…
Writing MVE view: view_0103.mve…
Writing MVE view: view_0104.mve…
Writing MVE view: view_0105.mve…
Writing MVE view: view_0106.mve…
Writing MVE view: view_0107.mve…
Writing MVE view: view_0108.mve…
Writing MVE view: view_0110.mve…
Writing MVE view: view_0109.mve…
Writing MVE view: view_0111.mve…
Writing MVE view: view_0112.mve…
Writing MVE view: view_0113.mve…
Writing MVE view: view_0114.mve…
Writing MVE view: view_0115.mve…
Writing MVE view: view_0116.mve…
Writing MVE view: view_0117.mve…
Writing MVE view: view_0118.mve…
Writing MVE view: view_0119.mve…
Writing MVE view: view_0120.mve…
Writing MVE view: view_0121.mve…
Writing MVE view: view_0122.mve…
Writing MVE view: view_0123.mve…
Writing MVE view: view_0124.mve…
Writing MVE view: view_0125.mve…
Writing MVE view: view_0126.mve…
Writing MVE view: view_0127.mve…
Writing MVE view: view_0128.mve…
Writing MVE view: view_0129.mve…
Writing MVE view: view_0130.mve…
Writing MVE view: view_0131.mve…
Writing MVE view: view_0132.mve…
Writing MVE view: view_0133.mve…
Writing MVE view: view_0134.mve…
Writing MVE view: view_0135.mve…
Writing MVE view: view_0136.mve…
Writing MVE view: view_0137.mve…
Writing MVE view: view_0138.mve…
Writing MVE view: view_0139.mve…
Writing MVE view: view_0140.mve…
Writing MVE view: view_0141.mve…
Writing MVE view: view_0142.mve…
Writing MVE view: view_0143.mve…
Writing MVE view: view_0144.mve…
Writing MVE view: view_0145.mve…
Writing MVE view: view_0146.mve…
Writing MVE view: view_0147.mve…
Writing MVE view: view_0148.mve…
Writing MVE view: view_0149.mve…
Writing MVE view: view_0150.mve…
Writing MVE view: view_0151.mve…
Writing MVE view: view_0152.mve…
Writing MVE view: view_0153.mve…
Writing MVE view: view_0154.mve…
Writing MVE view: view_0155.mve…
Writing MVE view: view_0156.mve…
Writing MVE view: view_0157.mve…
Writing MVE view: view_0158.mve…
Writing MVE view: view_0159.mve…
Writing MVE view: view_0160.mve…
Writing MVE view: view_0161.mve…
Writing MVE view: view_0162.mve…
Writing MVE view: view_0163.mve…
Writing MVE view: view_0164.mve…
Writing MVE view: view_0165.mve…
Writing MVE view: view_0166.mve…
Writing MVE view: view_0167.mve…
Writing MVE view: view_0168.mve…
Writing MVE view: view_0169.mve…
Writing MVE view: view_0170.mve…
Writing MVE view: view_0171.mve…
Writing MVE view: view_0172.mve…
Writing MVE view: view_0173.mve…
Writing MVE view: view_0175.mve…
Writing MVE view: view_0174.mve…
Writing MVE view: view_0176.mve…
Writing MVE view: view_0177.mve…
Writing MVE view: view_0178.mve…
Writing MVE view: view_0179.mve…
Writing MVE view: view_0180.mve…
Writing MVE view: view_0181.mve…
Writing MVE view: view_0182.mve…
Writing MVE view: view_0183.mve…
Writing MVE view: view_0184.mve…
Writing MVE view: view_0185.mve…
Writing MVE view: view_0186.mve…
Writing MVE view: view_0187.mve…
Writing MVE view: view_0188.mve…
Writing MVE view: view_0189.mve…
Writing MVE view: view_0190.mve…
Writing MVE view: view_0191.mve…
Writing MVE view: view_0192.mve…
Writing MVE view: view_0193.mve…
Writing MVE view: view_0194.mve…
Writing MVE view: view_0195.mve…
Writing MVE view: view_0197.mve…
Writing MVE view: view_0196.mve…
Writing MVE view: view_0198.mve…
Writing MVE view: view_0199.mve…
Writing MVE view: view_0200.mve…
Writing MVE view: view_0201.mve…
Writing MVE view: view_0202.mve…
Writing MVE view: view_0203.mve…
Writing MVE view: view_0204.mve…
Writing MVE view: view_0205.mve…
Writing MVE view: view_0206.mve…
Writing MVE view: view_0207.mve…
Writing MVE view: view_0208.mve…
Writing MVE view: view_0209.mve…
Writing MVE view: view_0210.mve…
Writing MVE view: view_0212.mve…
Writing MVE view: view_0211.mve…
Writing MVE view: view_0213.mve…
Writing MVE view: view_0214.mve…
Writing MVE view: view_0215.mve…
Writing MVE view: view_0216.mve…
Writing MVE view: view_0217.mve…
Writing MVE view: view_0218.mve…
Writing MVE view: view_0219.mve…
Writing MVE view: view_0220.mve…
Writing MVE view: view_0221.mve…
Writing MVE view: view_0222.mve…
Writing MVE view: view_0223.mve…
Writing MVE view: view_0224.mve…
Writing MVE view: view_0225.mve…
Writing MVE view: view_0226.mve…
Writing MVE view: view_0227.mve…
Writing MVE view: view_0228.mve…
Writing MVE view: view_0229.mve…
Writing MVE view: view_0230.mve…
Writing MVE view: view_0231.mve…
Writing MVE view: view_0232.mve…
Writing MVE view: view_0233.mve…
Writing MVE view: view_0234.mve…
Writing MVE view: view_0235.mve…
Writing MVE view: view_0236.mve…
Writing MVE view: view_0237.mve…
Writing MVE view: view_0238.mve…
Writing MVE view: view_0239.mve…
Writing MVE view: view_0241.mve…
Writing MVE view: view_0240.mve…
Writing MVE view: view_0242.mve…
Writing MVE view: view_0243.mve…
Writing MVE view: view_0244.mve…
Writing MVE view: view_0245.mve…
Writing MVE view: view_0247.mve…
Writing MVE view: view_0246.mve…
Writing MVE view: view_0248.mve…
Writing MVE view: view_0249.mve…
Writing MVE view: view_0250.mve…
Writing MVE view: view_0251.mve…
Writing MVE view: view_0252.mve…
Writing MVE view: view_0253.mve…
Writing MVE view: view_0254.mve…
Writing MVE view: view_0255.mve…
Writing MVE view: view_0256.mve…
Writing MVE view: view_0257.mve…
Writing MVE view: view_0258.mve…
Writing MVE view: view_0259.mve…
Writing MVE view: view_0260.mve…
Writing MVE view: view_0261.mve…
Writing MVE view: view_0262.mve…
Writing MVE view: view_0263.mve…
Writing MVE view: view_0264.mve…
Writing MVE view: view_0265.mve…
Writing MVE view: view_0266.mve…
Writing MVE view: view_0267.mve…
Writing MVE view: view_0268.mve…
Writing MVE view: view_0269.mve…
Writing MVE view: view_0270.mve…
Writing MVE view: view_0271.mve…
Writing MVE view: view_0272.mve…
Writing MVE view: view_0273.mve…
Writing MVE view: view_0274.mve…
Writing MVE view: view_0275.mve…
Writing MVE view: view_0276.mve…
Writing MVE view: view_0277.mve…
Writing MVE view: view_0278.mve…
Writing MVE view: view_0279.mve…
Writing MVE view: view_0280.mve…
Writing MVE view: view_0281.mve…
Writing MVE view: view_0282.mve…
Writing MVE view: view_0283.mve…
Writing MVE view: view_0284.mve…
Writing MVE view: view_0285.mve…
Writing MVE view: view_0286.mve…
Writing MVE view: view_0287.mve…
Writing MVE view: view_0288.mve…
Writing MVE view: view_0289.mve…
Writing MVE view: view_0290.mve…
Writing MVE view: view_0291.mve…
Writing MVE view: view_0292.mve…
Writing MVE view: view_0293.mve…
Writing MVE view: view_0294.mve…
Writing MVE view: view_0295.mve…
Writing MVE view: view_0296.mve…
Writing MVE view: view_0297.mve…
Writing MVE view: view_0298.mve…
Writing MVE view: view_0299.mve…
Writing MVE view: view_0300.mve…
Writing MVE view: view_0301.mve…
Writing MVE view: view_0302.mve…
Writing MVE view: view_0303.mve…
Writing MVE view: view_0304.mve…
Writing MVE view: view_0305.mve…
Writing MVE view: view_0306.mve…
Writing MVE view: view_0307.mve…
Writing MVE view: view_0308.mve…
Writing MVE view: view_0309.mve…
Writing MVE view: view_0310.mve…
Writing MVE view: view_0311.mve…
Writing MVE view: view_0312.mve…
Writing MVE view: view_0313.mve…
Writing MVE view: view_0314.mve…
Writing MVE view: view_0316.mve…
Writing MVE view: view_0315.mve…
Writing MVE view: view_0317.mve…
Writing MVE view: view_0318.mve…
Writing MVE view: view_0319.mve…
Writing MVE view: view_0320.mve…
Writing MVE view: view_0321.mve…
Writing MVE view: view_0322.mve…
Writing MVE view: view_0323.mve…
Writing MVE view: view_0324.mve…
Writing MVE view: view_0325.mve…
Writing MVE view: view_0326.mve…
Writing MVE view: view_0327.mve…
Writing MVE view: view_0328.mve…
Writing MVE view: view_0329.mve…
Writing MVE view: view_0330.mve…
Writing MVE view: view_0331.mve…
Writing MVE view: view_0332.mve…
Writing MVE view: view_0333.mve…
Writing MVE view: view_0334.mve…
Writing MVE view: view_0335.mve…
Writing MVE view: view_0338.mve…
Writing MVE view: view_0336.mve…
Writing MVE view: view_0337.mve…
Writing MVE view: view_0340.mve…
Writing MVE view: view_0339.mve…
Writing MVE view: view_0341.mve…
Writing MVE view: view_0342.mve…
Writing MVE view: view_0343.mve…
Writing MVE view: view_0344.mve…
Writing MVE view: view_0345.mve…
Writing MVE view: view_0346.mve…
Writing MVE view: view_0347.mve…
Writing MVE view: view_0348.mve…
Writing MVE view: view_0349.mve…
Writing MVE view: view_0350.mve…
Writing MVE view: view_0351.mve…
Writing MVE view: view_0352.mve…
Writing MVE view: view_0353.mve…
Writing MVE view: view_0354.mve…
Writing MVE view: view_0355.mve…
Writing MVE view: view_0356.mve…
Writing MVE view: view_0357.mve…
Writing MVE view: view_0358.mve…
Writing MVE view: view_0359.mve…
Writing MVE view: view_0360.mve…
Writing MVE view: view_0361.mve…
Writing MVE view: view_0362.mve…
Writing MVE view: view_0363.mve…
Writing MVE view: view_0364.mve…
Writing MVE view: view_0365.mve…
Writing MVE view: view_0366.mve…
Writing MVE view: view_0367.mve…
Writing MVE view: view_0368.mve…
Writing MVE view: view_0369.mve…
Writing MVE view: view_0370.mve…
Writing MVE view: view_0371.mve…
Writing MVE view: view_0372.mve…
Writing MVE view: view_0373.mve…
Writing MVE view: view_0374.mve…
Writing MVE view: view_0375.mve…
Writing MVE view: view_0376.mve…
Writing MVE view: view_0377.mve…
Writing MVE view: view_0378.mve…
Writing MVE view: view_0379.mve…
Writing MVE view: view_0380.mve…
Writing MVE view: view_0381.mve…
Writing MVE view: view_0382.mve…
Writing MVE view: view_0383.mve…
Writing MVE view: view_0385.mve…
Writing MVE view: view_0384.mve…
Writing MVE view: view_0386.mve…
Writing MVE view: view_0387.mve…
Writing MVE view: view_0388.mve…
Writing MVE view: view_0389.mve…
Writing MVE view: view_0390.mve…
Writing MVE view: view_0391.mve…
Writing MVE view: view_0392.mve…
Writing MVE view: view_0393.mve…
Writing MVE view: view_0394.mve…
Writing MVE view: view_0396.mve…
Writing MVE view: view_0395.mve…
Writing MVE view: view_0397.mve…
Writing MVE view: view_0398.mve…
Writing MVE view: view_0400.mve…
Writing MVE view: view_0399.mve…
Writing MVE view: view_0401.mve…
Writing MVE view: view_0402.mve…
Writing bundle file…
Writing bundle (403 cameras, 388506 features): /var/www/data/14aa563e-6709-42f0-a29d-2babf722de2d/mve/synth_0.out…
Done importing NVM file!
[INFO]
[INFO] ,/**
[INFO] ,
[INFO] ,/@%@&.
[INFO] ,
[INFO] ,
[INFO] ,/@&
[INFO] ,
[INFO] ,
[INFO] ,/@&
[INFO] ,
[INFO] ,
[INFO] ,
[INFO] .
[INFO] .
[INFO] .
[INFO] .
[INFO] .
[INFO] .
[INFO] /@
[INFO] ,
[INFO] #@/
[INFO] #@#
[INFO] */@#
[INFO] #@/
[INFO] #@#
[INFO] /@#(@@@@@@@&%/********&@.
[INFO] (@(
[INFO] (@%
[INFO] @%
[INFO] (@(
[INFO] ,(@%
[INFO] ,@%
[INFO] /@##@/
[INFO] ,/@&
[INFO] ,@&********%@/,
[INFO] /@#
[INFO] ,/@@@@(
[INFO] .**,
[INFO]
[INFO] Running dense reconstruction. This might take a while. Please be patient, the process is not dead or hung.
[INFO] Process is running
[INFO] running /code/SuperBuild/src/elibs/mve/apps/dmrecon/dmrecon -s2 --progress=silent --local-neighbors=2 “/var/www/data/14aa563e-6709-42f0-a29d-2babf722de2d/mve”
MVE Depth Map Reconstruction (built on Nov 19 2019, 17:32:26)
Initializing scene with 403 views…
Initialized 403 views (max ID is 402), took 16ms.
Reading Photosynther file (403 cameras, 388506 features)…
Reconstructing all views…
Definitely not normal; does it process in reasonable times without the GCP? Does restarting the process with the GCP get stuck at reconstructing all views (is it reproducible)?
Scenario 1 without a GCP file is processing successfully so far, now at Reconstructing All Views. Coming up on 2 hours. I will report back with any additional updates…
This is interesting. I have a dataset that fails with GCPs but completes without as well. I just thought it was a small fluke, perhaps data related (bad GCPs or similar).
After receiving the suggestions above from @pierotofy, I canceled and deleted the Task. WebODM in Chrome appeared to stall at this stage (not able to end task to exit the cancel/delete tasks) so I also deleted the “Project” altogether. I then ran ./webodm.sh start again in Powershell which seemed to purge out any old/canceled stored data. I probably should have ran './webodm.sh stop and './webodm.sh start though. Git Bash command prompt did show progress and WebODM appeared to run smoothly at this point.
Scenario 1 without GCP file completed successfully in 4-1/2 hours with 403 photos.
Then tested a Fast Ortho with GCP file, however the task stalled and no Task Output was being written. Here, I renamed the GCP file to be exactly “gcp_list.txt”, matching documentation & instructions. The task then completed successfully in 1 hour 43 minutes. (The browser GCP Interface outputs a text file named gcp_file_######.txt, or similar, with an appended timestamp or identification value so be sure to check this prior to initiating a Task with the GCP file).
I am now running a High-Res task with the GCP file. Based on the successful tests above and using the appropriately named GCP file, I expect the High-Res to complete later today and will provide an update at that time. If it works, I’ll try reproducing the original error by renaming the GCP file. Thanks @pierotofy !
