Radiometric Orthophotos
I’m using WebODM to build Orthophotos of solar farms. I would like to use the function radiometric calibration but as I’ve searched is not check and go. We need to tweak a little more.
Could anyone point me what what is the best settings to choose?
thanks
What sensor are you using that you’ve noticed the radiometric calibration in WebODM doesn’t work right with?
Hi Saijin_Naib,
I’m using Mavic 2 Enterprise advanced.
Are you able to provide the raw data and processed data in an issue on our GitHub so we can see about what needs to be improved in our DJI multispectral processing pipeline?
Sure.
Maybe I’m just doing something wrong. Do you have some guide lines, how to produce thermal orthophotos?
2 posts were split to a new topic: Thermal Radiometric Processing Zenmuse XTR
Have you have tested my data?
thanks
No, I have not yet. It is on the list :slight_smile:
Ok Saijin, that’s fair.
Please could you please text here what task options should I select when process radiometric thermal map?
wrong person
Sorry Pal, but since there are different drones cameras it may cause misunderstood.
Currently, I think the only option working with this drone is to convert images…
