New to webODM and running tests on my mac and PC for 3D modelling with my DJI Mavic.
I have a question about turning debugging off. So i start with
Simons-MacBook-Pro:WebODM simsurf$ ./webodm.sh start --no-debug
Checking for docker… OK
Checking for git… OK
Checking for python… OK
Checking for pip… OK
Starting WebODM…
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml start || docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml up
Starting db … done
Starting node-odm-1 … done
Starting webapp … done
But in the task list I still see [debug]?
e.g [DEBUG] Loaded 20171127_1122.JPG | camera: dji fc220 | dimensions: 2048 x 1536 | focal: 4.7 | ccd: 6.17 | lat: -28.0012027222 | lon: 153.350886833 | alt: 37.837
is this normal or am i doing something wrong?
