I’m curious about a couple of things with the Windows native WebODM install. I purchased the installer (I have it working in Linux and everything is great there, I don’t mind buying it again since it helps out the project.) and have some questions.
I processed the data set here: https://testhub.dronedb.app/r/beyondaerial/pj1ey2u3m04ruq5t on my Linux/Docker instance. A total of 763 images covering an area of approx. 90 acres.
I installed the Windows version of WebODM on the system that I use for Agisoft. I processed a smaller subset of data, 536 of the above images for roughly about 70 acres worth of area.
As you can see the processing time was significantly more for the smaller set of images. Is this normal, for the Windows version on similar hardware? (different processor, more cores on the Windows system, the same amount of memory, windows system has more powerful GPU, the Linux system has a low-end GPU.)
Does WebODM take advantage of GPU processing yet? (I’ve been out of the loop for about a year.)
