Quality. Enterprise Dual
Hello Everyone
I’m SUPER new to mapping. I have the Enterprise Dual. I’m wanting to make a 3D model. I used the preset settings of 70% overlapping and my photo turned out really "dotted’ looking. I’m assuming I need to increase my overlap.
My question what else can I do increase the quality.
Thank you for your time.
Roger
It would help out if you can post your processing parameters (console log) and it is recommended for a good 3d model that images should overlap by 85%.
Hello
Thank you for your reply. I did my first one at 70% and bumping to 85% I’m sure will make a big difference
Sorry for my ignorance how do I get to consol log?
Thank you in advance
Roger
console log can be downloaded from your task output. to the right of task output click the ON button, then on the right there is a little download , arrow button. Primarily the parameters used for the reconstruction will be in the top 40 or so lines.
when you click on “view 3d model” on the top left there should be a menu item that says “textured model”, you clicked on this and selected show model?
Yes I clicked textured. That made a huge difference.
Still not finding consol. Do you want camerA parameters?
Thank you and looking forward to hearing from you
I appreciate the help a lot, but I’m not finding that. I’m sorry I just downloaded it all tonight. Here’s the download I have. Where did you go to get that? Thank you so muchj.
Maybe this?
[INFO] Initializing ODM 2.8.8 - Fri Aug 19 04:12:44 2022
[INFO] ==============
[INFO] 3d_tiles: False
[INFO] auto_boundary: True
[INFO] auto_boundary_distance: 0
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_neighbors: 0
[INFO] matcher_type: flann
[INFO] max_concurrency: 4
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 300000
[INFO] name: d57a8242-07bf-4f0d-b91b-0ec4f2fd8f43
[INFO] no_gpu: False
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_copc: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_geometric: True
Yes that is the console log. Here is a tutorial another user posted a while back that explains a good method of capturing images for 3d models. Dronelink 3D Modeling - End to End on Vimeo
I would suggest fixing the gimbal pitch to non-nadir angle. something around -75 and if you want more detail and your WebODM machine can handle it is setting feature-quality to ultra and pc-quality to ultra. Theres a few other settings that can help as well like increasing mech octree and mesh size.
Thank you very much. I have a M1 chip set.
Could you tell me how do I make those changes you mentioned?
Thank you very much
just be aware that increasing feature quality and pc quality to ultra will have a big impact on the amount of ram webodm will require and if your machine does not have a lot of ram you may run into issues depending on the amount of images you are processing.
you can select to make changes to the task in the options / edit button and the task options will be there. If you can show off the final reconstruction
Thank you very much. I feel very lucky to have found this software. I thought I was going to be stuck with the crazy expensive drone deploy or something like that ha.
Thanks everyone
The highest setting is high i didn’t see an ultra.
The 3d map only has 36 photos with all pointing directly down so my next map I have an oblique setting I’ll do that with more photos.
Also attaching the console
Launching… please wait! This can take up to 5 minutes.
[INFO] boundary: {}
[INFO] cameras: {}
[INFO] cog: True
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_resolution: 2.0
[INFO] dsm: True
[INFO] dtm: False
[INFO] gcp: None
[INFO] geo: None
[INFO] merge: all
[INFO] mesh_size: 200000
[INFO] name: 5c25e8f1-d4d0-499b-94c5-b2cb70660c00
[INFO] optimize_disk_space: True
[INFO] orthophoto_resolution: 2.0
[INFO] pc_ept: True
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: high
[INFO] pc_rectify: False
[INFO] pc_sample: 0.01
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] rolling_shutter: False
[INFO] skip_3dmodel: False
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sky_removal: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/5c25e8f1-d4d0-499b-94c5-b2cb70660c00/images
[INFO] Loading 36 images
[INFO] Wrote images database: /var/www/data/5c25e8f1-d4d0-499b-94c5-b2cb70660c00/images.json
[INFO] Found 36 usable images
[INFO] Parsing SRS header: WGS84 UTM 16N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Maximum photo dimensions: 4056px
[INFO] Photo dimensions for feature extraction: 2028px
[INFO] nvidia-smi not found in PATH, using CPU
[INFO] [‘use_exif_size: no’, ‘flann_algorithm: KDTREE’, ‘feature_process_size: 2028’, ‘feature_min_frames: 10000’, ‘processes: 4’, ‘matching_gps_neighbors: 0’, ‘matching_gps_distance: 0’, ‘matching_graph_rounds: 50’, ‘optimize_camera_parameters: yes’, ‘reconstruction_algorithm: incremental’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘sift_peak_threshold: 0.066’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘retriangulation_ratio: 2’, ‘matcher_type: FLANN’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running “/code/SuperBuild/install/bin/opensfm/bin/opensfm” detect_features “/var/www/data/5c25e8f1-d4d0-499b-94c5-b2cb70660c00/opensfm”
2022-08-19 21:19:44,898 INFO: Planning to use 6339.174609375 MB of RAM for both processing queue and parallel processing.
2022-08-19 21:19:44,898 INFO: Scale-space expected size of a single image : 93.39873218536377 MB
2022-08-19 21:19:44,898 INFO: Expecting to queue at most 89 images while parallel processing of 4 images.
2022-08-19 21:19:44,901 INFO: Reading data for image DJI_0017.JPG (queue-size=0
2022-08-19 21:19:44,901 INFO: Reading data for image DJI_0007.JPG (queue-size=0
2022-08-19 21:19:45,100 INFO: Reading data for image DJI_0043.JPG (queue-size=1
2022-08-19 21:19:45,100 INFO: Extracting ROOT_SIFT features for image DJI_0007.JPG
2022-08-19 21:19:45,107 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:45,113 INFO: Reading data for image DJI_0059.JPG (queue-size=1
2022-08-19 21:19:45,113 INFO: Extracting ROOT_SIFT features for image DJI_0017.JPG
2022-08-19 21:19:45,121 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:45,277 INFO: Reading data for image DJI_0033.JPG (queue-size=1
2022-08-19 21:19:45,313 INFO: Reading data for image DJI_0049.JPG (queue-size=2
2022-08-19 21:19:45,465 INFO: Reading data for image DJI_0023.JPG (queue-size=3
2022-08-19 21:19:45,491 INFO: Reading data for image DJI_0067.JPG (queue-size=4
2022-08-19 21:19:45,657 INFO: Reading data for image DJI_0063.JPG (queue-size=5
2022-08-19 21:19:45,685 INFO: Reading data for image DJI_0057.JPG (queue-size=6
2022-08-19 21:19:45,839 INFO: Reading data for image DJI_0011.JPG (queue-size=7
2022-08-19 21:19:45,864 INFO: Reading data for image DJI_0047.JPG (queue-size=8
2022-08-19 21:19:46,018 INFO: Reading data for image DJI_0041.JPG (queue-size=9
2022-08-19 21:19:46,023 DEBUG: Found 23388 points in 0.9161078929901123s
2022-08-19 21:19:46,023 DEBUG: done
2022-08-19 21:19:46,035 INFO: Reading data for image DJI_0013.JPG (queue-size=10
2022-08-19 21:19:46,187 INFO: Reading data for image DJI_0031.JPG (queue-size=11
2022-08-19 21:19:46,220 INFO: Reading data for image DJI_0055.JPG (queue-size=12
2022-08-19 21:19:46,238 DEBUG: Found 38415 points in 1.1168577671051025s
2022-08-19 21:19:46,238 DEBUG: done
2022-08-19 21:19:46,362 INFO: Reading data for image DJI_0015.JPG (queue-size=13
2022-08-19 21:19:46,399 INFO: Reading data for image DJI_0053.JPG (queue-size=14
2022-08-19 21:19:46,546 INFO: Reading data for image DJI_0037.JPG (queue-size=15
2022-08-19 21:19:46,575 INFO: Reading data for image DJI_0029.JPG (queue-size=16
2022-08-19 21:19:46,716 INFO: Reading data for image DJI_0025.JPG (queue-size=17
2022-08-19 21:19:46,754 INFO: Reading data for image DJI_0027.JPG (queue-size=18
2022-08-19 21:19:46,899 INFO: Reading data for image DJI_0051.JPG (queue-size=19
2022-08-19 21:19:46,937 INFO: Reading data for image DJI_0003.JPG (queue-size=20
2022-08-19 21:19:47,074 INFO: Reading data for image DJI_0039.JPG (queue-size=21
2022-08-19 21:19:47,118 INFO: Reading data for image DJI_0065.JPG (queue-size=22
2022-08-19 21:19:47,270 INFO: Reading data for image DJI_0019.JPG (queue-size=23
2022-08-19 21:19:47,274 DEBUG: No segmentation for DJI_0007.JPG, no features masked.
2022-08-19 21:19:47,316 INFO: Reading data for image DJI_0035.JPG (queue-size=24
2022-08-19 21:19:47,473 INFO: Reading data for image DJI_0021.JPG (queue-size=25
2022-08-19 21:19:47,487 INFO: Reading data for image DJI_0073.JPG (queue-size=26
2022-08-19 21:19:47,656 INFO: Reading data for image DJI_0061.JPG (queue-size=27
2022-08-19 21:19:47,665 INFO: Reading data for image DJI_0009.JPG (queue-size=28
2022-08-19 21:19:47,843 INFO: Extracting ROOT_SIFT features for image DJI_0043.JPG
2022-08-19 21:19:47,844 INFO: Reading data for image DJI_0071.JPG (queue-size=28
2022-08-19 21:19:47,847 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:47,847 INFO: Reading data for image DJI_0069.JPG (queue-size=29
2022-08-19 21:19:48,034 INFO: Reading data for image DJI_0005.JPG (queue-size=30
2022-08-19 21:19:48,035 INFO: Reading data for image DJI_0045.JPG (queue-size=31
2022-08-19 21:19:48,040 DEBUG: No segmentation for DJI_0017.JPG, no features masked.
2022-08-19 21:19:48,208 INFO: Extracting ROOT_SIFT features for image DJI_0059.JPG
2022-08-19 21:19:48,213 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:48,215 INFO: Finished reading images
2022-08-19 21:19:48,215 INFO: Extracting ROOT_SIFT features for image DJI_0033.JPG
2022-08-19 21:19:48,220 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:48,441 DEBUG: Found 4498 points in 0.5932879447937012s
2022-08-19 21:19:48,441 DEBUG: reducing threshold
2022-08-19 21:19:48,441 DEBUG: Computing sift with threshold 0.044000000000000004
2022-08-19 21:19:48,938 DEBUG: Found 8459 points in 0.7181618213653564s
2022-08-19 21:19:48,938 DEBUG: reducing threshold
2022-08-19 21:19:48,939 DEBUG: Computing sift with threshold 0.044000000000000004
2022-08-19 21:19:48,950 INFO: Extracting ROOT_SIFT features for image DJI_0049.JPG
2022-08-19 21:19:48,955 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:49,107 DEBUG: Found 9655 points in 0.6659245491027832s
2022-08-19 21:19:49,107 DEBUG: reducing threshold
2022-08-19 21:19:49,107 DEBUG: Computing sift with threshold 0.029333333333333336
2022-08-19 21:19:49,219 DEBUG: Found 37039 points in 1.0058562755584717s
2022-08-19 21:19:49,219 DEBUG: done
2022-08-19 21:19:49,616 DEBUG: Found 8295 points in 0.6609330177307129s
2022-08-19 21:19:49,616 DEBUG: reducing threshold
2022-08-19 21:19:49,616 DEBUG: Computing sift with threshold 0.044000000000000004
2022-08-19 21:19:49,696 DEBUG: Found 14428 points in 0.7570159435272217s
2022-08-19 21:19:49,696 DEBUG: done
2022-08-19 21:19:49,823 DEBUG: Found 16869 points in 0.7158854007720947s
2022-08-19 21:19:49,823 DEBUG: done
2022-08-19 21:19:50,363 DEBUG: Found 15904 points in 0.7471649646759033s
2022-08-19 21:19:50,363 DEBUG: done
2022-08-19 21:19:50,624 DEBUG: No segmentation for DJI_0033.JPG, no features masked.
2022-08-19 21:19:50,771 DEBUG: No segmentation for DJI_0043.JPG, no features masked.
2022-08-19 21:19:50,959 DEBUG: No segmentation for DJI_0059.JPG, no features masked.
2022-08-19 21:19:50,967 INFO: Extracting ROOT_SIFT features for image DJI_0023.JPG
2022-08-19 21:19:50,972 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:51,168 INFO: Extracting ROOT_SIFT features for image DJI_0067.JPG
2022-08-19 21:19:51,172 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:51,329 DEBUG: No segmentation for DJI_0049.JPG, no features masked.
2022-08-19 21:19:51,699 INFO: Extracting ROOT_SIFT features for image DJI_0063.JPG
2022-08-19 21:19:51,704 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:51,834 INFO: Extracting ROOT_SIFT features for image DJI_0057.JPG
2022-08-19 21:19:51,838 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:51,999 DEBUG: Found 29149 points in 0.8265118598937988s
2022-08-19 21:19:51,999 DEBUG: done
2022-08-19 21:19:52,007 DEBUG: Found 57518 points in 1.0348894596099854s
2022-08-19 21:19:52,007 DEBUG: done
2022-08-19 21:19:52,592 DEBUG: Found 34191 points in 0.8882763385772705s
2022-08-19 21:19:52,593 DEBUG: done
2022-08-19 21:19:52,648 DEBUG: Found 25990 points in 0.8095493316650391s
2022-08-19 21:19:52,648 DEBUG: done
2022-08-19 21:19:53,423 DEBUG: No segmentation for DJI_0067.JPG, no features masked.
2022-08-19 21:19:53,973 DEBUG: No segmentation for DJI_0057.JPG, no features masked.
2022-08-19 21:19:54,111 INFO: Extracting ROOT_SIFT features for image DJI_0011.JPG
2022-08-19 21:19:54,116 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:54,200 DEBUG: No segmentation for DJI_0063.JPG, no features masked.
2022-08-19 21:19:54,379 DEBUG: No segmentation for DJI_0023.JPG, no features masked.
2022-08-19 21:19:54,638 INFO: Extracting ROOT_SIFT features for image DJI_0047.JPG
2022-08-19 21:19:54,643 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:54,889 DEBUG: Found 22300 points in 0.773137092590332s
2022-08-19 21:19:54,889 DEBUG: done
2022-08-19 21:19:55,073 INFO: Extracting ROOT_SIFT features for image DJI_0041.JPG
2022-08-19 21:19:55,078 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:55,199 DEBUG: Found 5305 points in 0.5551815032958984s
2022-08-19 21:19:55,199 DEBUG: reducing threshold
2022-08-19 21:19:55,199 DEBUG: Computing sift with threshold 0.044000000000000004
2022-08-19 21:19:55,632 DEBUG: Found 2760 points in 0.5539875030517578s
2022-08-19 21:19:55,633 DEBUG: reducing threshold
2022-08-19 21:19:55,633 DEBUG: Computing sift with threshold 0.044000000000000004
2022-08-19 21:19:55,788 INFO: Extracting ROOT_SIFT features for image DJI_0013.JPG
2022-08-19 21:19:55,792 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:55,845 DEBUG: Found 10594 points in 0.6460497379302979s
2022-08-19 21:19:55,846 DEBUG: done
2022-08-19 21:19:56,072 DEBUG: No segmentation for DJI_0011.JPG, no features masked.
2022-08-19 21:19:56,281 DEBUG: Found 6404 points in 0.6486506462097168s
2022-08-19 21:19:56,282 DEBUG: reducing threshold
2022-08-19 21:19:56,282 DEBUG: Computing sift with threshold 0.029333333333333336
2022-08-19 21:19:56,582 DEBUG: No segmentation for DJI_0047.JPG, no features masked.
2022-08-19 21:19:56,602 INFO: Extracting ROOT_SIFT features for image DJI_0031.JPG
2022-08-19 21:19:56,607 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:56,641 DEBUG: Found 31871 points in 0.848778486251831s
2022-08-19 21:19:56,642 DEBUG: done
2022-08-19 21:19:56,834 INFO: Extracting ROOT_SIFT features for image DJI_0055.JPG
2022-08-19 21:19:56,839 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:56,938 DEBUG: Found 11688 points in 0.6560080051422119s
2022-08-19 21:19:56,938 DEBUG: done
2022-08-19 21:19:57,263 DEBUG: Found 11868 points in 0.6563243865966797s
2022-08-19 21:19:57,263 DEBUG: done
2022-08-19 21:19:57,555 DEBUG: Found 19360 points in 0.7159733772277832s
2022-08-19 21:19:57,555 DEBUG: done
2022-08-19 21:19:57,721 DEBUG: No segmentation for DJI_0041.JPG, no features masked.
2022-08-19 21:19:57,995 INFO: Extracting ROOT_SIFT features for image DJI_0015.JPG
2022-08-19 21:19:58,000 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:58,035 DEBUG: No segmentation for DJI_0031.JPG, no features masked.
2022-08-19 21:19:58,197 DEBUG: No segmentation for DJI_0013.JPG, no features masked.
2022-08-19 21:19:58,315 INFO: Extracting ROOT_SIFT features for image DJI_0053.JPG
2022-08-19 21:19:58,319 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:58,607 DEBUG: No segmentation for DJI_0055.JPG, no features masked.
2022-08-19 21:19:58,862 DEBUG: Found 31688 points in 0.8617546558380127s
2022-08-19 21:19:58,862 DEBUG: done
2022-08-19 21:19:58,952 DEBUG: Found 12563 points in 0.6323363780975342s
2022-08-19 21:19:58,952 DEBUG: done
2022-08-19 21:19:58,981 INFO: Extracting ROOT_SIFT features for image DJI_0037.JPG
2022-08-19 21:19:58,986 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:59,070 INFO: Extracting ROOT_SIFT features for image DJI_0029.JPG
2022-08-19 21:19:59,075 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:19:59,512 DEBUG: Found 4291 points in 0.5258791446685791s
2022-08-19 21:19:59,512 DEBUG: reducing threshold
2022-08-19 21:19:59,512 DEBUG: Computing sift with threshold 0.044000000000000004
2022-08-19 21:19:59,771 DEBUG: No segmentation for DJI_0053.JPG, no features masked.
2022-08-19 21:19:59,778 DEBUG: Found 23437 points in 0.7034094333648682s
2022-08-19 21:19:59,778 DEBUG: done
2022-08-19 21:20:00,076 INFO: Extracting ROOT_SIFT features for image DJI_0025.JPG
2022-08-19 21:20:00,081 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:00,131 DEBUG: Found 9514 points in 0.6192636489868164s
2022-08-19 21:20:00,132 DEBUG: reducing threshold
2022-08-19 21:20:00,132 DEBUG: Computing sift with threshold 0.029333333333333336
2022-08-19 21:20:00,370 DEBUG: No segmentation for DJI_0015.JPG, no features masked.
2022-08-19 21:20:00,811 DEBUG: Found 15795 points in 0.6786816120147705s
2022-08-19 21:20:00,811 DEBUG: done
2022-08-19 21:20:00,969 DEBUG: Found 35162 points in 0.8874940872192383s
2022-08-19 21:20:00,969 DEBUG: done
2022-08-19 21:20:00,971 DEBUG: No segmentation for DJI_0029.JPG, no features masked.
2022-08-19 21:20:01,119 INFO: Extracting ROOT_SIFT features for image DJI_0027.JPG
2022-08-19 21:20:01,123 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:01,547 INFO: Extracting ROOT_SIFT features for image DJI_0051.JPG
2022-08-19 21:20:01,552 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:01,767 DEBUG: No segmentation for DJI_0037.JPG, no features masked.
2022-08-19 21:20:01,956 DEBUG: Found 30879 points in 0.8326654434204102s
2022-08-19 21:20:01,956 DEBUG: done
2022-08-19 21:20:02,110 DEBUG: Found 7602 points in 0.5582437515258789s
2022-08-19 21:20:02,110 DEBUG: reducing threshold
2022-08-19 21:20:02,110 DEBUG: Computing sift with threshold 0.044000000000000004
2022-08-19 21:20:02,150 INFO: Extracting ROOT_SIFT features for image DJI_0003.JPG
2022-08-19 21:20:02,154 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:02,656 DEBUG: No segmentation for DJI_0025.JPG, no features masked.
2022-08-19 21:20:02,799 DEBUG: Found 16010 points in 0.6883502006530762s
2022-08-19 21:20:02,799 DEBUG: done
2022-08-19 21:20:02,860 DEBUG: Found 21886 points in 0.7051265239715576s
2022-08-19 21:20:02,860 DEBUG: done
2022-08-19 21:20:03,461 DEBUG: No segmentation for DJI_0027.JPG, no features masked.
2022-08-19 21:20:03,524 INFO: Extracting ROOT_SIFT features for image DJI_0039.JPG
2022-08-19 21:20:03,528 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:03,730 DEBUG: No segmentation for DJI_0051.JPG, no features masked.
2022-08-19 21:20:04,002 DEBUG: No segmentation for DJI_0003.JPG, no features masked.
2022-08-19 21:20:04,070 DEBUG: Found 5433 points in 0.5416460037231445s
2022-08-19 21:20:04,070 DEBUG: reducing threshold
2022-08-19 21:20:04,070 DEBUG: Computing sift with threshold 0.044000000000000004
2022-08-19 21:20:04,110 INFO: Extracting ROOT_SIFT features for image DJI_0065.JPG
2022-08-19 21:20:04,114 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:04,200 INFO: Extracting ROOT_SIFT features for image DJI_0019.JPG
2022-08-19 21:20:04,204 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:04,544 INFO: Extracting ROOT_SIFT features for image DJI_0035.JPG
2022-08-19 21:20:04,549 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:04,722 DEBUG: Found 10458 points in 0.6520698070526123s
2022-08-19 21:20:04,722 DEBUG: done
2022-08-19 21:20:05,048 DEBUG: Found 52131 points in 0.9331619739532471s
2022-08-19 21:20:05,048 DEBUG: done
2022-08-19 21:20:05,152 DEBUG: Found 7583 points in 0.6028077602386475s
2022-08-19 21:20:05,152 DEBUG: reducing threshold
2022-08-19 21:20:05,152 DEBUG: Computing sift with threshold 0.044000000000000004
2022-08-19 21:20:05,299 DEBUG: Found 65050 points in 1.0941710472106934s
2022-08-19 21:20:05,299 DEBUG: done
2022-08-19 21:20:05,452 DEBUG: No segmentation for DJI_0039.JPG, no features masked.
2022-08-19 21:20:05,700 INFO: Extracting ROOT_SIFT features for image DJI_0021.JPG
2022-08-19 21:20:05,704 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:05,786 DEBUG: Found 13205 points in 0.6332547664642334s
2022-08-19 21:20:05,786 DEBUG: done
2022-08-19 21:20:06,592 DEBUG: Found 34060 points in 0.88804030418396s
2022-08-19 21:20:06,593 DEBUG: done
2022-08-19 21:20:06,594 DEBUG: No segmentation for DJI_0035.JPG, no features masked.
2022-08-19 21:20:06,902 INFO: Extracting ROOT_SIFT features for image DJI_0073.JPG
2022-08-19 21:20:06,907 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:07,194 DEBUG: No segmentation for DJI_0065.JPG, no features masked.
2022-08-19 21:20:07,482 DEBUG: Found 10895 points in 0.5747668743133545s
2022-08-19 21:20:07,482 DEBUG: done
2022-08-19 21:20:07,946 DEBUG: No segmentation for DJI_0019.JPG, no features masked.
2022-08-19 21:20:08,205 DEBUG: No segmentation for DJI_0073.JPG, no features masked.
2022-08-19 21:20:08,257 DEBUG: No segmentation for DJI_0021.JPG, no features masked.
2022-08-19 21:20:08,467 INFO: Extracting ROOT_SIFT features for image DJI_0009.JPG
2022-08-19 21:20:08,471 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:08,508 INFO: Extracting ROOT_SIFT features for image DJI_0061.JPG
2022-08-19 21:20:08,513 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:09,061 INFO: Extracting ROOT_SIFT features for image DJI_0069.JPG
2022-08-19 21:20:09,066 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:09,114 DEBUG: Found 19672 points in 0.6423707008361816s
2022-08-19 21:20:09,114 DEBUG: done
2022-08-19 21:20:09,502 INFO: Extracting ROOT_SIFT features for image DJI_0071.JPG
2022-08-19 21:20:09,507 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:09,520 DEBUG: Found 57704 points in 1.007279872894287s
2022-08-19 21:20:09,521 DEBUG: done
2022-08-19 21:20:09,842 DEBUG: Found 26295 points in 0.776268720626831s
2022-08-19 21:20:09,842 DEBUG: done
2022-08-19 21:20:10,167 DEBUG: No segmentation for DJI_0009.JPG, no features masked.
2022-08-19 21:20:10,181 DEBUG: Found 14789 points in 0.674048900604248s
2022-08-19 21:20:10,181 DEBUG: done
2022-08-19 21:20:10,644 INFO: Extracting ROOT_SIFT features for image DJI_0045.JPG
2022-08-19 21:20:10,649 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:11,080 DEBUG: No segmentation for DJI_0071.JPG, no features masked.
2022-08-19 21:20:11,121 DEBUG: Found 4223 points in 0.47223949432373047s
2022-08-19 21:20:11,121 DEBUG: reducing threshold
2022-08-19 21:20:11,121 DEBUG: Computing sift with threshold 0.044000000000000004
2022-08-19 21:20:11,177 DEBUG: No segmentation for DJI_0069.JPG, no features masked.
2022-08-19 21:20:11,431 INFO: Extracting ROOT_SIFT features for image DJI_0005.JPG
2022-08-19 21:20:11,435 DEBUG: Computing sift with threshold 0.066
2022-08-19 21:20:11,689 DEBUG: Found 9075 points in 0.5676088333129883s
2022-08-19 21:20:11,689 DEBUG: reducing threshold
2022-08-19 21:20:11,689 DEBUG: Computing sift with threshold 0.029333333333333336
2022-08-19 21:20:11,924 DEBUG: No segmentation for DJI_0061.JPG, no features masked.
2022-08-19 21:20:12,174 DEBUG: Found 23479 points in 0.7389276027679443s
2022-08-19 21:20:12,174 DEBUG: done
2022-08-19 21:20:12,320 DEBUG: Found 15762 points in 0.6306014060974121s
2022-08-19 21:20:12,320 DEBUG: done
2022-08-19 21:20:13,221 DEBUG: No segmentation for DJI_0045.JPG, no features masked.
2022-08-19 21:20:13,377 DEBUG: No segmentation for DJI_0005.JPG, no features masked.
[INFO] running “/code/SuperBuild/install/bin/opensfm/bin/opensfm” match_features “/var/www/data/5c25e8f1-d4d0-499b-94c5-b2cb70660c00/opensfm”
2022-08-19 21:20:14,687 INFO: Altitude is negative (-4525.177988495592) : viewing directions are probably divergent. Using default altitude of 1.0
2022-08-19 21:20:14,687 INFO: Altitude for orientation based matching 1.0
2022-08-19 21:20:14,706 INFO: Matching 295 image pairs
2022-08-19 21:20:14,712 INFO: Computing pair matching with 4 processes
2022-08-19 21:20:14,762 DEBUG: No segmentation for DJI_0047.JPG, no features masked.
2022-08-19 21:20:14,778 DEBUG: No segmentation for DJI_0037.JPG, no features masked.
2022-08-19 21:20:14,803 DEBUG: No segmentation for DJI_0007.JPG, no features masked.
2022-08-19 21:20:14,807 DEBUG: No segmentation for DJI_0053.JPG, no features masked.
2022-08-19 21:20:14,815 DEBUG: No segmentation for DJI_0057.JPG, no features masked.
2022-08-19 21:20:14,823 DEBUG: No segmentation for DJI_0041.JPG, no features masked.
2022-08-19 21:20:14,877 DEBUG: No segmentation for DJI_0011.JPG, no features masked.
2022-08-19 21:20:15,159 DEBUG: Matching DJI_0047.JPG and DJI_0053.JPG. Matcher: FLANN (symmetric) T-desc: 0.430 T-robust: 0.014 T-total: 0.443 Matches: 51 Robust: 12 Success: False
2022-08-19 21:20:15,222 DEBUG: Matching DJI_0037.JPG and DJI_0041.JPG. Matcher: FLANN (symmetric) T-desc: 0.505 T-robust: 0.001 T-total: 0.507 Matches: 579 Robust: 537 Success: True
2022-08-19 21:20:15,266 DEBUG: No segmentation for DJI_0033.JPG, no features masked.
2022-08-19 21:20:15,317 DEBUG: No segmentation for DJI_0065.JPG, no features masked.
2022-08-19 21:20:15,347 DEBUG: Matching DJI_0057.JPG and DJI_0053.JPG. Matcher: FLANN (symmetric) T-desc: 0.626 T-robust: 0.006 T-total: 0.632 Matches: 95 Robust: 55 Success: True
2022-08-19 21:20:15,435 DEBUG: No segmentation for DJI_0059.JPG, no features masked.
Were you using Lightning? It doesn’t have ultra feature extraction. You need to use your own machine to be able to use ultra feature extraction.
Yes. I have a M1 Mac
Also here’s my settings for the autonomous flight. Do they look close?
Going from 36 photos to 200+ at a top down level and side levels big difference.
Any ideas as to how I can get ultra setting? I’m using the M1 Apple processor. It’s one of the most powerful processors out there so I can’t image why I’m not getting ultra setttings?
Thank you very much!!!
