I am having issues in the latest QGIS with viewing point clouds in QGIS. Is anyone else seeing this: untwine is generating the ept directory, but only the extent is showing. If I load a previously loaded point cloud or generate my own ept, it still doesn’t display.
I see a possibly related issue:
opened 03:36PM - 17 Jul 21 UTC
closed 01:43PM - 09 Aug 21 UTC
Bug
Point Clouds
Checklist before submitting
- [x] Search through existing issue reports and g… is.stackexchange.com to check whether the issue already exists
- [x] Test with a [clean new user profile](https://docs.qgis.org/testing/en/docs/user_manual/introduction/qgis_configuration.html?highlight=profile#working-with-user-profiles).
- [x] Create a light and self-contained sample dataset and project file which demonstrates the issue
**Describe the bug**
I am trying to import a laz file into QGIS 3.20.0 but point cloud does not show up at all.
I tried with QGIS in OSGeo4W installer and with Standalone installers (MSI) from OSGeo4W packages. Same result.
I tried with also with QGIS 3.18.3, but I get same result as before.
Apparently QGIS correctly imports the laz file creating the necessary folders and files, but nothing is displayed and no error is reported.
2021-07-17T17:13:35 INFO Processed 200000 points
2021-07-17T17:13:35 INFO Processed 300000 points
2021-07-17T17:13:36 INFO Processed 400000 points
2021-07-17T17:13:36 INFO Processed 500000 points
2021-07-17T17:13:36 INFO Processed 600000 points
2021-07-17T17:13:36 INFO Processed 700000 points
2021-07-17T17:13:36 INFO Processed 800000 points
2021-07-17T17:13:36 INFO Processed 900000 points
2021-07-17T17:13:36 INFO Processed 1000000 points
2021-07-17T17:13:36 INFO Processed 1100000 points
2021-07-17T17:13:37 INFO Processed 1200000 points
2021-07-17T17:13:37 INFO Processed 1300000 points
2021-07-17T17:13:37 INFO Processed 1400000 points
2021-07-17T17:13:37 INFO Processed 1600000 points
2021-07-17T17:13:37 INFO Processed 1700000 points
2021-07-17T17:13:37 INFO Processed 1800000 points
2021-07-17T17:13:37 INFO Processed 1900000 points
2021-07-17T17:13:38 INFO Processed 2000000 points
2021-07-17T17:13:38 INFO Processed 2100000 points
2021-07-17T17:13:38 INFO Processed 2200000 points
2021-07-17T17:13:38 INFO Processed 2300000 points
2021-07-17T17:13:38 INFO Processed 2400000 points
2021-07-17T17:13:38 INFO Processed 2500000 points
2021-07-17T17:13:38 INFO Processed 2600000 points
2021-07-17T17:13:38 INFO Processed 2700000 points
2021-07-17T17:13:39 INFO Processed 2800000 points
2021-07-17T17:13:39 INFO Processed 2900000 points
2021-07-17T17:13:39 INFO Processed 3100000 points
2021-07-17T17:13:39 INFO Processed 3200000 points
2021-07-17T17:13:39 INFO Processed 3300000 points
2021-07-17T17:13:39 INFO Processed 3400000 points
2021-07-17T17:13:39 INFO Processed 3500000 points
2021-07-17T17:13:40 INFO Processed 3500000 points
2021-07-17T17:13:40 INFO Processed 3600000 points
2021-07-17T17:13:40 INFO Processed 3700000 points
2021-07-17T17:13:40 INFO Processed 3800000 points
2021-07-17T17:13:40 INFO Processed 3900000 points
2021-07-17T17:13:40 INFO Processed 4000000 points
2021-07-17T17:13:40 INFO Processed 4100000 points
2021-07-17T17:13:41 INFO Processed 4200000 points
2021-07-17T17:13:41 INFO Processed 4289199 points
2021-07-17T17:13:42 INFO Processed 4289199 points
2021-07-17T17:13:43 INFO Processed 4289199 points
2021-07-17T17:13:43 INFO Sample complete for 2-2-3-1
2021-07-17T17:13:43 INFO Sample complete for 2-1-3-1
2021-07-17T17:13:44 INFO Sample complete for 2-1-3-1
2021-07-17T17:13:45 INFO Sample complete for 2-1-3-1
2021-07-17T17:13:45 INFO Rimozione file temporari in temp
Removing and re-importing the file an error pop on:
`Folder $$ is non-empty, but there isn't ept.json present.`
**How to Reproduce**
1. Open QGIS.
2. Import laz file and waiting for initializing.
3. No point cloud show up.
4. Remove layer.
5. Re-import laz file.
6. An critical error from untwine pop on.
You can get an example of file here: https://drive.google.com/file/d/1FWmAP5hG3CtNxQ5DpJ6I9nHbC_SZ5D28/view?usp=sharing (it is a lidar from http://centrodedescargas.cnig.es).
**QGIS and OS versions**
Software | Version
QGIS | 3.20.0-Odense
Qt | 5.15.2
Python | 3.9.5
GDAL/OGR | 3.3.1
PROJ | 8.1.0
EPSG Registry database | v10.027 (2021-06-17)
GEOS | 3.9.1-CAPI-1.14.2
SQLite | 3.35.2
PDAL | 2.3.0
PostgreSQL client | 13.0
SpatiaLite | 5.0.1
QWT | 6.1.3
QScintilla2 | 2.11.5
OS | Windows 10 Version 2009
**Additional context**
Digging aroud I find out [this one](https://github.com/OpenDroneMap/ODM/issues/1237#issuecomment-797383604) and it seems this also apply to my case, because lidar scale is around e-07. Following [this one](https://github.com/hobu/untwine/issues/53#issuecomment-785353568) I tried to rescale with pdal lidar scale but got `PDAL: writers.las: Unable to convert scaled value (4160002000) to int32 for dimension 'X'` (same as [here](https://github.com/hobu/untwine/issues/46)). I also try to upgrade pdal from 2.2 to 2.3 as mention [here](https://github.com/hobu/untwine/issues/60?_pjax=%23repo-content-pjax-container) but nothing changes.
QGIS version
3.20.1-Odense
QGIS code revision
2755615b9f
Qt version
5.12.8
Python version
3.8.10
GDAL/OGR version
3.0.4
PROJ version
6.3.1
EPSG Registry database version
v9.8.6 (2020-01-22)
Compiled against GEOS
3.8.0-CAPI-1.13.1
Running against GEOS
3.8.0-CAPI-1.13.1
SQLite version
3.31.1
PDAL version
2.0.1
PostgreSQL client version
12.7 (Ubuntu 12.7-0ubuntu0.20.04.1)
SpatiaLite version
4.3.0a
QWT version
6.1.4
QScintilla2 version
2.11.2
OS version
Ubuntu 20.04.2 LTS
Active Python plugins
Qgis2threejs
OSMDownloader
mapswipetool_plugin
processing
db_manager
MetaSearch
I’ve not checked in a while, but I’ll try when I get home to my Windows desktop. The Flatpak of QGIS is still being compiled without PDAL.
Maybe the back-level PDAL that Ubuntu is shipping is causing issues?
I am uncertain if something got fixed in an update, or if I fixed it with the following, but I noted that for QGIS I wasn’t specifically invoking use of 64-bit packages. I changed my /etc/apt/sources.list
entry from:
deb https://qgis.org/ubuntu focal main
to
deb [arch=amd64] https://qgis.org/ubuntu focal main
I use CloudCompare for fiddling with point clouds.
It’s possible to export DSM/DEM to.
system
Closed
28 September 2021 07:08
#7
