These are the last lines …
/code/SuperBuild/src/opensfm/bin/opensfm create_tracks “/var/www/data/bfa16a14-bf06-4433-a91c-0799c3f49023/opensfm”",“2019-12-31 18:04:21,196 INFO: reading features”,“2019-12-31 18:04:24,052 DEBUG: Merging features onto tracks”,“2019-12-31 18:04:24,139 DEBUG: Good tracks: 11872”,"[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm reconstruct “/var/www/data/bfa16a14-bf06-4433-a91c-0799c3f49023/opensfm”",“2019-12-31 18:04:25,302 INFO: Starting incremental reconstruction”,“2019-12-31 18:04:25,414 INFO: 0 partial reconstructions in total.”,"[INFO] Updating /var/www/data/bfa16a14-bf06-4433-a91c-0799c3f49023/opensfm/config.yaml","[INFO] undistorted_image_max_size: 5472","[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm undistort “/var/www/data/bfa16a14-bf06-4433-a91c-0799c3f49023/opensfm”","[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm export_visualsfm --undistorted --points “/var/www/data/bfa16a14-bf06-4433-a91c-0799c3f49023/opensfm”",“Traceback (most recent call last):”,“File “/code/SuperBuild/src/opensfm/bin/opensfm”, line 34, in “,“command.run(args)”,“File “/code/SuperBuild/src/opensfm/opensfm/commands/export_visualsfm.py”, line 30, in run”,“reconstructions = data.load_undistorted_reconstruction()”,“File “/code/SuperBuild/src/opensfm/opensfm/dataset.py”, line 585, in load_undistorted_reconstruction”,“filename=‘undistorted_reconstruction.json’)”,“File “/code/SuperBuild/src/opensfm/opensfm/dataset.py”, line 575, in load_reconstruction”,“with io.open_rt(self._reconstruction_file(filename)) as fin:”,“File “/code/SuperBuild/src/opensfm/opensfm/io.py”, line 555, in open_rt”,“return io.open(path, ‘r’, encoding=‘utf-8’)”,“IOError”,”: [Errno 2] No such file or directory: ‘/var/www/data/bfa16a14-bf06-4433-a91c-0799c3f49023/opensfm/undistorted_reconstruction.json’”,“Traceback (most recent call last):”,“File “/code/run.py”, line 57, in “,“app.execute()”,“File “/code/stages/odm_app.py”, line 92, in execute”,“self.first_stage.run()”,“File “/code/opendm/types.py”, line 370, in run”,“self.next_stage.run(outputs)”,“File “/code/opendm/types.py”, line 370, in run”,“self.next_stage.run(outputs)”,“File “/code/opendm/types.py”, line 370, in run”,“self.next_stage.run(outputs)”,“File “/code/opendm/types.py”, line 351, in run”,“self.process(self.args, outputs)”,“File “/code/stages/run_opensfm.py”, line 70, in process”,“octx.run(‘export_visualsfm --undistorted --points’)”,“File “/code/opendm/osfm.py”, line 21, in run”,”(context.opensfm_path, command, self.opensfm_project_path))”,“File “/code/opendm/system.py”, line 76, in run”,“raise Exception(“Child returned {}”.format(retcode))”,“Exception: Child returned 1”]
