I’m fairly new to WebODM. What does it mean when it says, “PyOpenCL is missing (not a GPU build)”
Basically that ODM didn’t detect PyOpenCL installed, so it will not attempt to do GPU processing.
This is likely a non-issue as it should still CPU process just fine.
How do you have it installed, and what platform are you on?
Yup! This looks like an error, but it’s just fine. It is only an error if you are trying to run on GPUs. But as running on GPUs won’t give anyone much of a speed bump yet, you can consider it an experimental feature at this stage.
I just changed that message, hopefully it will cause less confusion.
[INFO] Not using the GPU
Yeah, not bad!
