Dataset URL (Dropbox, Google Drive, GitHub…):
https://drive.google.com/drive/folders/1KfXt6-PwOCQpu3X3U4Nv8jjUokhFD86k?usp=sharing
Number of images: Many
Size in MB: Many
EXIF GPS (yes/no): Yes
GCP (yes/no): Mixed
RTK (yes/no): No
Comment/Description:
This is where I will be sharing imagery from my UAS Capstone from here on out. The images captured will be from several different platforms, some of which will have multiple sensors in the same flight. I will post a new comment to this thread each time a new dataset gets uploaded.
Some of our systems:
C-Astral Bramor PPX
- PPK enabled fixed wing aerial platform with a Sony RX1R II
- Micasense Altum multispectral sensor can be interchanged with RX1R II
DJI Matrice 600 Pro
- DJI X5 RGB gimbal
- Will likely be carrying the Altum in future flights
Yuneec Typhoon H
- Standard RGB sensor
- Currently out for repairs
DJI Matrice 100
- DJI “Smart Farmers bundle”
- Carries either an X3 RGB or X3 NIR gimbal sensor
- Can also carry a Micasense Red Edge multispectral camera
Terms of use:
If you wish to use any of the images from the dataset for personal experimentation or software testing, you are free to do so. If you use the images for anything beyond personal use, make sure you credit the Purdue University Unmanned Aerial Systems program. Commercial use of the images is not permitted without explicit permission. You are free to share any of the data in the drive as long as the recipients receive the same terms of use.
