PublicLabs - MapKnitter Integration
MapKnitter is a FOSS atlas for aerial photogrammetry using PublicLabs products.
It would be interesting to see about import/export to this resource within the context of ODM. Also, I see a lot of common ideals between the two communities.
Yes, I have long thought there should be some relationship between OpenDroneMap and mapknitter, though they do occupy slightly different niches. Maybe if you are doing something in WebODM and you don’t have enough images, it could fall back to mapknitter… . :slight_smile:
That works… I was also thinking about it as an alternative export space when compared to something like OpenAerialMap, perhaps even in parallel.
