Project files allocated
Hi Piero,
I work with Natively on Ubuntu 16.04 Server, Chrome 62 on Mac OS X 10.
I would like to know where the files of individual projects are allocated?
For example ortophoto,dem,ecc…
Tks
Hi @Marcuzzo77, by default files are stored in a named docker volume ( https://docs.docker.com/engine/admin/volumes/volumes/ ), but you can switch to a file system mapped volume by passing the --media-dir flag to ./webodm.sh. See the README for more information https://github.com/OpenDroneMap/WebODM#where-are-my-files-stored
I started to reprocess the image set using the suggested changes in the options you mentioned.
Last time, the docker container (C:\Users\Pitman.docker\machine\machines\default) grew greatly in size. This time, I looked at the docs and when I started WebODM I specified a folder on my hard drive in this manner:
After starting the docker terminal, I entered the following:
./webodm.sh start --media-dir folder-name
I didn’t capture an image of the details of what happened in the terminal, but it appeared like everything was in order. Note, I did not actually create the folder as I expected it would be created by the process.
I then opened WebODM in the browser and started the project. Well, it didn’t create a folder and that original docker container is growing now.
I expected the process to create the folder and put the project in it but that’s not what it did. Where did I go wrong.
Thank you.
ps: I did select fast orthophoto in the settings. Is it going to have that image somewhere before the rest of the processing is done? Or maybe I am misinterpreting the objective for using it. I was thinking it would produce an orthophoto in a relative short time compared to the standard processing.
I think you need to create the folder yourself, docker is not going to create it. Also make sure that you issue a ./webodm.sh down before anything else.
--fast-orthophoto will create an orthophoto more quickly, but will not create a full 3D model. It’s an experimental feature (and we need more testing on WebODM), so if you notice something is not working (is the orthophoto not being generated?) please file a bug report.
