Project fails when combining nadir and oblique datasets
I’ve successfully run the nadir and oblique sets independently using the fast-ortho, but when I combine the two and customize the settings it errors out. I’ve included text from the console report below.
settings:
[INFO] Initializing ODM 2.9.2 - Wed Nov 09 02:52:16 2022
[INFO] ==============
[INFO] 3d_tiles: False
[INFO] auto_boundary: True
[INFO] auto_boundary_distance: 0
[INFO] bg_removal: False
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: True
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: True
[INFO] matcher_neighbors: 0
[INFO] matcher_type: flann
[INFO] max_concurrency: 128
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 300000
[INFO] name: cbef36be-b4be-4ec7-9d7e-f5388bcb491d
[INFO] no_gpu: False
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_copc: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 1.0
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] rolling_shutter: False
[INFO] skip_3dmodel: False
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sky_removal: False
[INFO] sm_cluster: None
[INFO] sm_no_align: False
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
Process (top):
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/images
[INFO] Loading 891 images
[INFO] Found 891 usable images
[INFO] Parsing SRS header: WGS84 UTM 10N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Maximum photo dimensions: 5472px
[INFO] Photo dimensions for feature extraction: 2736px
[INFO] nvidia-smi not found in PATH, using CPU
[INFO] [‘use_exif_size: no’, ‘flann_algorithm: KDTREE’, ‘feature_process_size: 2736’, ‘feature_min_frames: 10000’, ‘processes: 128’, ‘matching_gps_neighbors: 0’, ‘matching_gps_distance: 0’, ‘matching_graph_rounds: 50’, ‘optimize_camera_parameters: yes’, ‘reconstruction_algorithm: incremental’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘sift_peak_threshold: 0.066’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘retriangulation_ratio: 2’, ‘matcher_type: FLANN’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running “/code/SuperBuild/install/bin/opensfm/bin/opensfm” detect_features “/var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm”
2022-11-09 02:52:24,655 INFO: Planning to use 221628.50507812502 MB of RAM for both processing queue and parallel processing.
2022-11-09 02:52:24,655 INFO: Scale-space expected size of a single image : 170.66471099853516 MB
2022-11-09 02:52:24,655 INFO: Expecting to queue at most 200 images while parallel processing of 128 images.
Process (btm):
2022-11-09 09:30:25,426 DEBUG: Undistorting image DJI_0155.JPG
[INFO] running “/code/SuperBuild/install/bin/opensfm/bin/opensfm” export_visualsfm --points “/var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm”
[INFO] Finished opensfm stage
[INFO] Running openmvs stage
[INFO] running “/code/SuperBuild/install/bin/opensfm/bin/opensfm” export_openmvs “/var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm”
[INFO] Depthmap resolution set to: 684px
[INFO] Estimating depthmaps
[INFO] running “/code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud” “/var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm/undistorted/openmvs/scene.mvs” --resolution-level 3 --dense-config-file “/var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm/undistorted/openmvs/Densify.ini” --min-resolution 684 --max-resolution 5472 --max-threads 128 --number-views-fuse 2 --sub-resolution-levels 2 -w “/var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm/undistorted/openmvs/depthmaps” -v 0 --cuda-device -2 --geometric-iters 0
09:34:32 [App ] Build date: Oct 23 2022, 00:34:16
09:34:32 [App ] CPU: AMD EPYC 7601 32-Core Processor (128 cores)
09:34:32 [App ] RAM: 251.75GB Physical Memory 2.00GB Virtual Memory
09:34:32 [App ] OS: Linux 5.15.0-52-generic (x86_64)
09:34:32 [App ] Disk:
09:34:32 [App ] SSE & AVX compatible CPU & OS detected
09:34:32 [App ] Command line: DensifyPointCloud /var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm/undistorted/openmvs/scene.mvs --resolution-level 3 --dense-config-file /var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm/undistorted/openmvs/Densify.ini --min-resolution 684 --max-resolution 5472 --max-threads 128 --number-views-fuse 2 --sub-resolution-levels 2 -w /var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm/undistorted/openmvs/depthmaps -v 0 --cuda-device -2 --geometric-iters 0
09:34:33 [App ] Find a camera not pointing towards the scene center; the scene will be considered unbounded (no ROI)
09:35:06 [App ] Preparing images for dense reconstruction completed: 891 images (33s443ms)
09:35:19 [App ] Selecting images for dense reconstruction completed: 0 images (12s936ms)
Fused depth-maps 0 (100%, 0ms)
09:35:19 [App ] Densifying point-cloud completed: 0 points (46s597ms)
09:35:19 [App ] MEMORYINFO: {
09:35:19 [App ] VmPeak: 36390128 kB
09:35:19 [App ] VmSize: 19041848 kB
09:35:19 [App ] } ENDINFO
[INFO] running “/code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud” --filter-point-cloud -1 -i “/var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm/undistorted/openmvs/scene_dense.mvs” -v 0 --cuda-device -2 --geometric-iters 0
09:35:20 [App ] Build date: Oct 23 2022, 00:34:16
09:35:20 [App ] CPU: AMD EPYC 7601 32-Core Processor (128 cores)
09:35:20 [App ] RAM: 251.75GB Physical Memory 2.00GB Virtual Memory
09:35:20 [App ] OS: Linux 5.15.0-52-generic (x86_64)
09:35:20 [App ] Disk:
09:35:20 [App ] SSE & AVX compatible CPU & OS detected
09:35:20 [App ] Command line: DensifyPointCloud --filter-point-cloud -1 -i /var/www/data/cbef36be-b4be-4ec7-9d7e-f5388bcb491d/opensfm/undistorted/openmvs/scene_dense.mvs -v 0 --cuda-device -2 --geometric-iters 0
09:35:20 [App ] error: no valid point-cloud for the ROI estimation
Info for Geeks:
Child returned 1
File “/code/stages/odm_app.py”, line 88, in execute
File “/code/opendm/types.py”, line 378, in run
File “/code/opendm/types.py”, line 359, in run
File “/code/stages/openmvs.py”, line 209, in process
system.run(’"%s" %s’ % (context.omvs_densify_path, ’ '.join(config + gpu_config + extra_config)))
File “/code/opendm/system.py”, line 109, in run
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See Flying Tips — OpenDroneMap 2.9.1 documentation
You definitely can’t combine angles with fast orthophoto. Nadir only, really.
Try defaults and then if that works, turn up the feature-quality and pc-quality .
I only ran fast ortho on the individual sets. Seemed to work ok with the oblique but I haven’t looked it over too closely. For the combined set, it’s turned off. This section really has me scratching my chin-
Yeah, I’m confused about that too. But have you run either of the individual sets with defaults? Fast-orthophoto is quite a bit different as a toolchain from the usual approach.
I haven’t. I’ll run one tonight.
Just for sanity’s sake, unless you have just an absurd amount of RAM, please drop --ignore-gsd unless you’re 1000% sure you need it.
Missed that. He does have an insane amount of ram, but maybe not that much.
I ran the combined set with default settings and got the same error. The only difference was it errored out after 4 hours this time compared to 6.5 hours last time. One thing to note - I restarted the same project that failed from “load data set”.
[INFO] running “/code/SuperBuild/install/bin/opensfm/bin/opensfm” export_visualsfm --points “/var/www/data/53c552a6-d2e5-4202-b5df-3818d66dbbc5/opensfm”
[INFO] running “/code/SuperBuild/install/bin/opensfm/bin/opensfm” export_openmvs “/var/www/data/53c552a6-d2e5-4202-b5df-3818d66dbbc5/opensfm”
[INFO] nvidia-smi detected
[INFO] running “/code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud” “/var/www/data/53c552a6-d2e5-4202-b5df-3818d66dbbc5/opensfm/undistorted/openmvs/scene.mvs” --resolution-level 0 --dense-config-file “/var/www/data/53c552a6-d2e5-4202-b5df-3818d66dbbc5/opensfm/undistorted/openmvs/Densify.ini” --min-resolution 684 --max-resolution 684 --max-threads 128 --number-views-fuse 2 --sub-resolution-levels 2 -w “/var/www/data/53c552a6-d2e5-4202-b5df-3818d66dbbc5/opensfm/undistorted/openmvs/depthmaps” -v 0 --cuda-device -1 --geometric-iters 0
09:30:24 [App ] Build date: Nov 7 2022, 22:48:40
09:30:24 [App ] CPU: AMD EPYC 7601 32-Core Processor (128 cores)
09:30:24 [App ] RAM: 251.75GB Physical Memory 2.00GB Virtual Memory
09:30:24 [App ] OS: Linux 5.15.0-52-generic (x86_64)
09:30:24 [App ] Disk:
09:30:24 [App ] SSE & AVX compatible CPU & OS detected
09:30:24 [App ] Command line: DensifyPointCloud /var/www/data/53c552a6-d2e5-4202-b5df-3818d66dbbc5/opensfm/undistorted/openmvs/scene.mvs --resolution-level 0 --dense-config-file /var/www/data/53c552a6-d2e5-4202-b5df-3818d66dbbc5/opensfm/undistorted/openmvs/Densify.ini --min-resolution 684 --max-resolution 684 --max-threads 128 --number-views-fuse 2 --sub-resolution-levels 2 -w /var/www/data/53c552a6-d2e5-4202-b5df-3818d66dbbc5/opensfm/undistorted/openmvs/depthmaps -v 0 --cuda-device -1 --geometric-iters 0
09:30:24 [App ] MapSMtoCores for SM 8.6 is undefined; default to use 64 cores/SM
09:30:25 [App ] Find a camera not pointing towards the scene center; the scene will be considered unbounded (no ROI)
09:30:25 [App ] Preparing images for dense reconstruction completed: 891 images (400ms)
09:30:31 [App ] Selecting images for dense reconstruction completed: 0 images (6s187ms)
09:30:31 [App ] Densifying point-cloud completed: 0 points (6s718ms)
09:30:31 [App ] MEMORYINFO: {
09:30:31 [App ] VmPeak: 14816832 kB
09:30:31 [App ] VmSize: 14751296 kB
09:30:31 [App ] } ENDINFO
[INFO] running “/code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud” --filter-point-cloud -1 -i “/var/www/data/53c552a6-d2e5-4202-b5df-3818d66dbbc5/opensfm/undistorted/openmvs/scene_dense.mvs” -v 0 --cuda-device -1 --geometric-iters 0
09:30:32 [App ] Build date: Nov 7 2022, 22:48:40
09:30:32 [App ] CPU: AMD EPYC 7601 32-Core Processor (128 cores)
09:30:32 [App ] RAM: 251.75GB Physical Memory 2.00GB Virtual Memory
09:30:32 [App ] OS: Linux 5.15.0-52-generic (x86_64)
09:30:32 [App ] Disk:
09:30:32 [App ] SSE & AVX compatible CPU & OS detected
09:30:32 [App ] Command line: DensifyPointCloud --filter-point-cloud -1 -i /var/www/data/53c552a6-d2e5-4202-b5df-3818d66dbbc5/opensfm/undistorted/openmvs/scene_dense.mvs -v 0 --cuda-device -1 --geometric-iters 0
09:30:32 [App ] MapSMtoCores for SM 8.6 is undefined; default to use 64 cores/SM
09:30:32 [App ] error: no valid point-cloud for the ROI estimation
Child returned 1
File “/code/opendm/types.py”, line 380, in run
File “/code/opendm/types.py”, line 361, in run
File “/code/stages/openmvs.py”, line 226, in process
raise e
File “/code/stages/openmvs.py”, line 220, in process
I’m running the nadir set using the default settings now. I previously ran the nadir set using fast ortho & no gpu and it took 1:07 mins. This time I’m using default settings with gpu. If anything, this will be an interesting comparison.
Thanks Saijin and Smather for troubleshooting with me!
Any insight into this line?
Should “Disk” be blank?
Maybe you need to increase virtual memory initial size significantly, and make it equal to max size?
Sure, I’ll give it a shot. How do I set the initial size? I’m brand new to Ubuntu. Also, I noticed this warning upon WebODM start-up - “overcommit_memory is set to 0”. I don’t see a sysctl.conf file in the etc directory…
Update on the nadir set:
It ran fine with the default settings.
One difference between this finished project and the failed one (bold):
[INFO] running “/code/SuperBuild/install/bin/opensfm/bin/opensfm” export_visualsfm --points “/var/www/data/d2762d03-2214-42d2-a0ea-a2c3550b164f/opensfm”
[INFO] running “/code/SuperBuild/install/bin/opensfm/bin/opensfm” export_openmvs “/var/www/data/d2762d03-2214-42d2-a0ea-a2c3550b164f/opensfm”
[INFO] running “/code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud” “/var/www/data/d2762d03-2214-42d2-a0ea-a2c3550b164f/opensfm/undistorted/openmvs/scene.mvs” --resolution-level 1 --dense-config-file “/var/www/data/d2762d03-2214-42d2-a0ea-a2c3550b164f/opensfm/undistorted/openmvs/Densify.ini” --min-resolution 684 --max-resolution 1741 --max-threads 128 --number-views-fuse 2 --sub-resolution-levels 2 -w “/var/www/data/d2762d03-2214-42d2-a0ea-a2c3550b164f/opensfm/undistorted/openmvs/depthmaps” -v 0 --cuda-device -1 --geometric-iters 0
18:16:20 [App ] Build date: Nov 7 2022, 22:48:40
18:16:20 [App ] CPU: AMD EPYC 7601 32-Core Processor (128 cores)
18:16:20 [App ] RAM: 251.75GB Physical Memory 2.00GB Virtual Memory
18:16:20 [App ] OS: Linux 5.15.0-52-generic (x86_64)
18:16:20 [App ] Disk:
18:16:20 [App ] SSE & AVX compatible CPU & OS detected
18:16:20 [App ] Command line: DensifyPointCloud /var/www/data/d2762d03-2214-42d2-a0ea-a2c3550b164f/opensfm/undistorted/openmvs/scene.mvs --resolution-level 1 --dense-config-file /var/www/data/d2762d03-2214-42d2-a0ea-a2c3550b164f/opensfm/undistorted/openmvs/Densify.ini --min-resolution 684 --max-resolution 1741 --max-threads 128 --number-views-fuse 2 --sub-resolution-levels 2 -w /var/www/data/d2762d03-2214-42d2-a0ea-a2c3550b164f/opensfm/undistorted/openmvs/depthmaps -v 0 --cuda-device -1 --geometric-iters 0
18:16:20 [App ] MapSMtoCores for SM 8.6 is undefined; default to use 64 cores/SM
18:16:21 [App ] The camera directions mean is unbalanced; the scene will be considered unbounded (no ROI)
18:16:22 [App ] Preparing images for dense reconstruction completed: 294 images (1s79ms)
18:16:24 [App ] Selecting images for dense reconstruction completed: 294 images (2s723ms)
Just noticed “resolution-level 0” from the failed project. That’s different.
Have you run the non-combined duo each with defaults?
I ran the nadir this morning, went fine. Running the oblique now. I’ll report back shortly.
I don’t know how to set it in Unbuntu, but for docker I think it needs to be in a .wslconfig file
It needs to be on a fast drive, and perhaps equal to your RAM, plus set min = max size
Update - the oblique set failed with default settings.
22:09:30 [App ] Preparing images for dense reconstruction completed: 597 images (284ms)
22:09:34 [App ] Selecting images for dense reconstruction completed: 0 images (3s582ms)
Potential problems:
2022-11-11 19:35:19,443 INFO: Altitude is negative (-256.67766603640365) : viewing directions are probably divergent. Using default altitude of 1.0
[WARNING] Negative GSD estimated, this might indicate a flipped Z-axis.
These flights were flown sequentially using a P4 and Pix4D capture. The only difference was changing the camera angle on the last 2 flights from within Pix4D capture to 55 deg (from the horizon).
What are the overlap/sidelap for the obliques? It is possible we’re not getting good reconstruction so it is throwing everything out.
I didn’t change the overlap from the nadir set, so, if I remember correctly, 90 / 75. The altitude was the same as well.
Best results thus far for the oblique set. Any thoughts on how I could clean this up?
settings:
Can your machine handle --feature-quality ultra, --pc-quality ultra, and upping --matcher-neighbors 32?
Also, do you have an idea of your mean GPS accuracy for this collect? Passing it to --gps-accuracy might help constrain things a bit more.
Finally, trying it with --rolling-shutter might help even more.
