I am experiencing this error when I attempt to open the IP on my browser using Firefox. Any ideas on how this can be resolved? Thanks in advance!
ProgrammingError at /
relation “auth_user” does not exist
LINE 1: SELECT COUNT(*) AS “__count” FROM “auth_user” WHERE "auth_us…
Request Method: GET
Request URL: http://192.168.99.100:8000/
Django Version: 1.11.7
Exception Type: ProgrammingError
Exception Value:
Exception Location: /usr/local/lib/python3.5/site-packages/django/db/backends/utils.py in execute, line 65
Python Executable: /usr/local/bin/python
Python Version: 3.5.4
Python Path:
[‘/webodm’,
‘/usr/local/bin’,
‘/webodm’,
‘/usr/local/lib/python35.zip’,
‘/usr/local/lib/python3.5’,
‘/usr/local/lib/python3.5/plat-linux’,
‘/usr/local/lib/python3.5/lib-dynload’,
‘/usr/local/lib/python3.5/site-packages’]
Server time: Mon, 5 Feb 2018 01:27:04 +0000
Traceback Switch to copy-and-paste view
return self.cursor.execute(sql, params)
▶ Local vars
The above exception (relation "auth_user" does not exist LINE 1: SELECT COUNT(*) AS "__count" FROM "auth_user" WHERE "auth_us... ^ ) was the direct cause of the following exception:
/usr/local/lib/python3.5/site-packages/django/core/handlers/exception.py in inner
response = get_response(request)
▶ Local vars
/usr/local/lib/python3.5/site-packages/django/core/handlers/base.py in _get_response
response = self.process_exception_by_middleware(e, request)
▶ Local vars
response = wrapped_callback(request, *callback_args, **callback_kwargs)
▶ Local vars
/webodm/app/views/app.py in index
if User.objects.filter(is_superuser=True).count() == 0:
▶ Local vars
/usr/local/lib/python3.5/site-packages/django/db/models/query.py in count
return self.query.get_count(using=self.db)
▶ Local vars
/usr/local/lib/python3.5/site-packages/django/db/models/sql/query.py in get_count
number = obj.get_aggregation(using, ['__count'])['__count']
▶ Local vars
/usr/local/lib/python3.5/site-packages/django/db/models/sql/query.py in get_aggregation
result = compiler.execute_sql(SINGLE)
▶ Local vars
/usr/local/lib/python3.5/site-packages/django/db/models/sql/compiler.py in execute_sql
raise original_exception
▶ Local vars
▶ Local vars
return super(CursorDebugWrapper, self).execute(sql, params)
▶ Local vars
▶ Local vars
/usr/local/lib/python3.5/site-packages/django/db/utils.py in __exit__
six.reraise(dj_exc_type, dj_exc_value, traceback)
▶ Local vars
/usr/local/lib/python3.5/site-packages/django/utils/six.py in reraise
raise value.with_traceback(tb)
▶ Local vars
▶ Local vars
Request information
USER
AnonymousUser
GET
No GET data
POST
No POST data
FILES
No FILES data
COOKIES
Variable Value
csrftoken
‘sr48Avp7EKcBi7mQFOidWOf9VCw2eZCeocPaURQLvwxyzBYHMPpRNCZRwDqdNJF4’
META
Variable Value
CSRF_COOKIE
HTTP_ACCEPT
‘text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8’
HTTP_ACCEPT_ENCODING
‘gzip, deflate’
HTTP_ACCEPT_LANGUAGE
‘en-US,en;q=0.5’
HTTP_CACHE_CONTROL
‘max-age=0’
HTTP_CONNECTION
‘close’
HTTP_COOKIE
‘csrftoken=sr48Avp7EKcBi7mQFOidWOf9VCw2eZCeocPaURQLvwxyzBYHMPpRNCZRwDqdNJF4’
HTTP_HOST
‘192.168.99.100:8000’
HTTP_UPGRADE_INSECURE_REQUESTS
‘1’
HTTP_USER_AGENT
‘Mozilla/5.0 (Windows NT 6.1; WOW64; rv:58.0) Gecko/20100101 Firefox/58.0’
HTTP_X_FORWARDED_FOR
‘192.168.99.1’
PATH_INFO
QUERY_STRING
RAW_URI
REMOTE_ADDR
REQUEST_METHOD
‘GET’
SCRIPT_NAME
SERVER_NAME
‘192.168.99.100’
SERVER_PORT
‘8000’
SERVER_PROTOCOL
‘HTTP/1.0’
SERVER_SOFTWARE
‘gunicorn/19.7.1’
gunicorn.socket
<socket.socket fd=13, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=/tmp/gunicorn.sock>
wsgi.errors
<gunicorn.http.wsgi.WSGIErrorsWrapper object at 0x7fb4929376d8>
wsgi.file_wrapper
wsgi.input
<gunicorn.http.body.Body object at 0x7fb4929372b0>
wsgi.multiprocess
False
wsgi.multithread
False
wsgi.run_once
False
wsgi.url_scheme
‘http’
wsgi.version
(1, 0)
Settings
Using settings module webodm.settings
Setting Value
ABSOLUTE_URL_OVERRIDES
ADMINS
ALLOWED_HOSTS
APPEND_SLASH
True
AUTHENTICATION_BACKENDS
(‘django.contrib.auth.backends.ModelBackend’,
‘guardian.backends.ObjectPermissionBackend’)
AUTH_PASSWORD_VALIDATORS
AUTH_USER_MODEL
‘auth.User’
BASE_DIR
‘/webodm’
CACHES
{‘default’: {‘BACKEND’: ‘django.core.cache.backends.locmem.LocMemCache’}}
CACHE_MIDDLEWARE_ALIAS
‘default’
CACHE_MIDDLEWARE_KEY_PREFIX
CACHE_MIDDLEWARE_SECONDS
600
COMPRESS_CACHEABLE_PRECOMPILERS
COMPRESS_CACHE_BACKEND
‘default’
COMPRESS_CACHE_KEY_FUNCTION
COMPRESS_CLEAN_CSS_ARGUMENTS
COMPRESS_CLEAN_CSS_BINARY
‘cleancss’
COMPRESS_CLOSURE_COMPILER_ARGUMENTS
COMPRESS_CLOSURE_COMPILER_BINARY
‘java -jar compiler.jar’
COMPRESS_CSS_COMPRESSOR
‘compressor.css.CssCompressor’
COMPRESS_CSS_FILTERS
[‘compressor.filters.css_default.CssAbsoluteFilter’]
COMPRESS_CSS_HASHING_METHOD
‘mtime’
COMPRESS_DATA_URI_MAX_SIZE
1024
COMPRESS_DEBUG_TOGGLE
None
COMPRESS_ENABLED
False
COMPRESS_JINJA2_GET_ENVIRONMENT
<function CompressorConf.JINJA2_GET_ENVIRONMENT at 0x7fb493c4d488>
COMPRESS_JS_COMPRESSOR
‘compressor.js.JsCompressor’
COMPRESS_JS_FILTERS
[‘compressor.filters.jsmin.JSMinFilter’]
COMPRESS_MINT_DELAY
30
COMPRESS_MTIME_DELAY
10
COMPRESS_OFFLINE
False
COMPRESS_OFFLINE_CONTEXT
{‘STATIC_URL’: ‘/static/’}
COMPRESS_OFFLINE_MANIFEST
‘manifest.json’
COMPRESS_OFFLINE_TIMEOUT
31536000
COMPRESS_OUTPUT_DIR
‘CACHE’
COMPRESS_PARSER
‘compressor.parser.AutoSelectParser’
COMPRESS_PRECOMPILERS
((‘text/x-scss’, ‘django_libsass.SassCompiler’),)
COMPRESS_REBUILD_TIMEOUT
2592000
COMPRESS_ROOT
‘/webodm/build/static’
COMPRESS_STORAGE
‘compressor.storage.CompressorFileStorage’
COMPRESS_TEMPLATE_FILTER_CONTEXT
COMPRESS_URL
‘/static/’
COMPRESS_URL_PLACEHOLDER
‘/compressor_url_placeholder/’
COMPRESS_VERBOSE
False
COMPRESS_YUGLIFY_BINARY
‘yuglify’
COMPRESS_YUGLIFY_CSS_ARGUMENTS
‘–terminal’
COMPRESS_YUGLIFY_JS_ARGUMENTS
‘–terminal’
COMPRESS_YUI_BINARY
‘java -jar yuicompressor.jar’
COMPRESS_YUI_CSS_ARGUMENTS
COMPRESS_YUI_JS_ARGUMENTS
CORS_ORIGIN_ALLOW_ALL
True
CSRF_COOKIE_AGE
31449600
CSRF_COOKIE_DOMAIN
None
CSRF_COOKIE_HTTPONLY
False
CSRF_COOKIE_NAME
‘csrftoken’
CSRF_COOKIE_PATH
CSRF_COOKIE_SECURE
False
CSRF_FAILURE_VIEW
‘django.views.csrf.csrf_failure’
CSRF_HEADER_NAME
‘HTTP_X_CSRFTOKEN’
CSRF_TRUSTED_ORIGINS
CSRF_USE_SESSIONS
False
DATABASES
{‘default’: {‘ATOMIC_REQUESTS’: False,
‘AUTOCOMMIT’: True,
‘CONN_MAX_AGE’: 0,
‘ENGINE’: ‘django.contrib.gis.db.backends.postgis’,
‘HOST’: ‘db’,
‘NAME’: ‘webodm_dev’,
‘OPTIONS’: {},
‘PASSWORD’: ‘********************’,
‘PORT’: ‘5432’,
‘TEST’: {‘CHARSET’: None,
‘COLLATION’: None,
‘MIRROR’: None,
‘NAME’: None},
‘TIME_ZONE’: None,
‘USER’: ‘postgres’}}
DATABASE_ROUTERS
DATA_UPLOAD_MAX_MEMORY_SIZE
2621440
DATA_UPLOAD_MAX_NUMBER_FIELDS
None
DATETIME_FORMAT
‘N j, Y, P’
DATETIME_INPUT_FORMATS
[‘%Y-%m-%d %H:%M:%S’,
‘%Y-%m-%d %H:%M:%S.%f’,
‘%Y-%m-%d %H:%M’,
‘%Y-%m-%d’,
‘%m/%d/%Y %H:%M:%S’,
‘%m/%d/%Y %H:%M:%S.%f’,
‘%m/%d/%Y %H:%M’,
‘%m/%d/%Y’,
‘%m/%d/%y %H:%M:%S’,
‘%m/%d/%y %H:%M:%S.%f’,
‘%m/%d/%y %H:%M’,
‘%m/%d/%y’]
DATE_FORMAT
‘N j, Y’
DATE_INPUT_FORMATS
[‘%Y-%m-%d’,
‘%m/%d/%Y’,
‘%m/%d/%y’,
‘%b %d %Y’,
‘%b %d, %Y’,
‘%d %b %Y’,
‘%d %b, %Y’,
‘%B %d %Y’,
‘%B %d, %Y’,
‘%d %B %Y’,
‘%d %B, %Y’]
DEBUG
True
DEBUG_PROPAGATE_EXCEPTIONS
False
DECIMAL_SEPARATOR
DEFAULT_CHARSET
‘utf-8’
DEFAULT_CONTENT_TYPE
‘text/html’
DEFAULT_EXCEPTION_REPORTER_FILTER
‘django.views.debug.SafeExceptionReporterFilter’
DEFAULT_FILE_STORAGE
‘django.core.files.storage.FileSystemStorage’
DEFAULT_FROM_EMAIL
DEFAULT_INDEX_TABLESPACE
DEFAULT_TABLESPACE
DISALLOWED_USER_AGENTS
EMAIL_BACKEND
‘django.core.mail.backends.smtp.EmailBackend’
EMAIL_HOST
‘localhost’
EMAIL_HOST_PASSWORD
EMAIL_HOST_USER
EMAIL_PORT
25
EMAIL_SSL_CERTFILE
None
EMAIL_SSL_KEYFILE
EMAIL_SUBJECT_PREFIX
'[Django] ’
EMAIL_TIMEOUT
None
EMAIL_USE_LOCALTIME
False
EMAIL_USE_SSL
False
EMAIL_USE_TLS
False
FILE_CHARSET
‘utf-8’
FILE_UPLOAD_DIRECTORY_PERMISSIONS
None
FILE_UPLOAD_HANDLERS
[‘django.core.files.uploadhandler.MemoryFileUploadHandler’,
‘app.uploadhandler.TemporaryFileUploadHandler’]
FILE_UPLOAD_MAX_MEMORY_SIZE
4718592
FILE_UPLOAD_PERMISSIONS
None
FILE_UPLOAD_TEMP_DIR
None
FIRST_DAY_OF_WEEK
0
FIXTURE_DIRS
FORCE_SCRIPT_NAME
None
FORMAT_MODULE_PATH
None
FORM_RENDERER
‘django.forms.renderers.DjangoTemplates’
IGNORABLE_404_URLS
IMAGEKIT_CACHEFILE_DIR
‘CACHE/images’
IMAGEKIT_CACHEFILE_NAMER
‘imagekit.cachefiles.namers.hash’
IMAGEKIT_CACHE_BACKEND
‘default’
IMAGEKIT_CACHE_PREFIX
‘imagekit:’
IMAGEKIT_CACHE_TIMEOUT
300
IMAGEKIT_DEFAULT_CACHEFILE_BACKEND
‘imagekit.cachefiles.backends.Simple’
IMAGEKIT_DEFAULT_CACHEFILE_STRATEGY
‘imagekit.cachefiles.strategies.JustInTime’
IMAGEKIT_DEFAULT_FILE_STORAGE
IMAGEKIT_SPEC_CACHEFILE_NAMER
‘imagekit.cachefiles.namers.source_name_as_path’
IMAGEKIT_USE_MEMCACHED_SAFE_CACHE_KEY
INSTALLED_APPS
[‘django.contrib.admin’,
‘django.contrib.auth’,
‘django.contrib.contenttypes’,
‘django.contrib.sessions’,
‘django.contrib.messages’,
‘django.contrib.staticfiles’,
‘django.contrib.gis’,
‘django_filters’,
‘guardian’,
‘rest_framework’,
‘rest_framework_nested’,
‘webpack_loader’,
‘corsheaders’,
‘colorfield’,
‘imagekit’,
‘codemirror2’,
‘compressor’,
‘app’,
‘nodeodm’]
INTERNAL_IPS
[‘127.0.0.1’]
JWT_AUTH
{‘JWT_EXPIRATION_DELTA’: datetime.timedelta(0, 21600)}
LANGUAGES
[(‘af’, ‘Afrikaans’),
(‘ar’, ‘Arabic’),
(‘ast’, ‘Asturian’),
(‘az’, ‘Azerbaijani’),
(‘bg’, ‘Bulgarian’),
(‘be’, ‘Belarusian’),
(‘bn’, ‘Bengali’),
(‘br’, ‘Breton’),
(‘bs’, ‘Bosnian’),
(‘ca’, ‘Catalan’),
(‘cs’, ‘Czech’),
(‘cy’, ‘Welsh’),
(‘da’, ‘Danish’),
(‘de’, ‘German’),
(‘dsb’, ‘Lower Sorbian’),
(‘el’, ‘Greek’),
(‘en’, ‘English’),
(‘en-au’, ‘Australian English’),
(‘en-gb’, ‘British English’),
(‘eo’, ‘Esperanto’),
(‘es’, ‘Spanish’),
(‘es-ar’, ‘Argentinian Spanish’),
(‘es-co’, ‘Colombian Spanish’),
(‘es-mx’, ‘Mexican Spanish’),
(‘es-ni’, ‘Nicaraguan Spanish’),
(‘es-ve’, ‘Venezuelan Spanish’),
(‘et’, ‘Estonian’),
(‘eu’, ‘Basque’),
(‘fa’, ‘Persian’),
(‘fi’, ‘Finnish’),
(‘fr’, ‘French’),
(‘fy’, ‘Frisian’),
(‘ga’, ‘Irish’),
(‘gd’, ‘Scottish Gaelic’),
(‘gl’, ‘Galician’),
(‘he’, ‘Hebrew’),
(‘hi’, ‘Hindi’),
(‘hr’, ‘Croatian’),
(‘hsb’, ‘Upper Sorbian’),
(‘hu’, ‘Hungarian’),
(‘ia’, ‘Interlingua’),
(‘id’, ‘Indonesian’),
(‘io’, ‘Ido’),
(‘is’, ‘Icelandic’),
(‘it’, ‘Italian’),
(‘ja’, ‘Japanese’),
(‘ka’, ‘Georgian’),
(‘kk’, ‘Kazakh’),
(‘km’, ‘Khmer’),
(‘kn’, ‘Kannada’),
(‘ko’, ‘Korean’),
(‘lb’, ‘Luxembourgish’),
(‘lt’, ‘Lithuanian’),
(‘lv’, ‘Latvian’),
(‘mk’, ‘Macedonian’),
(‘ml’, ‘Malayalam’),
(‘mn’, ‘Mongolian’),
(‘mr’, ‘Marathi’),
(‘my’, ‘Burmese’),
(‘nb’, ‘Norwegian Bokmål’),
(‘ne’, ‘Nepali’),
(‘nl’, ‘Dutch’),
(‘nn’, ‘Norwegian Nynorsk’),
(‘os’, ‘Ossetic’),
(‘pa’, ‘Punjabi’),
(‘pl’, ‘Polish’),
(‘pt’, ‘Portuguese’),
(‘pt-br’, ‘Brazilian Portuguese’),
(‘ro’, ‘Romanian’),
(‘ru’, ‘Russian’),
(‘sk’, ‘Slovak’),
(‘sl’, ‘Slovenian’),
(‘sq’, ‘Albanian’),
(‘sr’, ‘Serbian’),
(‘sr-latn’, ‘Serbian Latin’),
(‘sv’, ‘Swedish’),
(‘sw’, ‘Swahili’),
(‘ta’, ‘Tamil’),
(‘te’, ‘Telugu’),
(‘th’, ‘Thai’),
(‘tr’, ‘Turkish’),
(‘tt’, ‘Tatar’),
(‘udm’, ‘Udmurt’),
(‘uk’, ‘Ukrainian’),
(‘ur’, ‘Urdu’),
(‘vi’, ‘Vietnamese’),
(‘zh-hans’, ‘Simplified Chinese’),
(‘zh-hant’, ‘Traditional Chinese’)]
LANGUAGES_BIDI
[‘he’, ‘ar’, ‘fa’, ‘ur’]
LANGUAGE_CODE
‘en-us’
LANGUAGE_COOKIE_AGE
None
LANGUAGE_COOKIE_DOMAIN
None
LANGUAGE_COOKIE_NAME
‘django_language’
LANGUAGE_COOKIE_PATH
LIBSASS_CUSTOM_FUNCTIONS
{‘complementary’: <function complementary at 0x7fb4ac871bf8>,
‘scaleby’: <function scaleby at 0x7fb4ac871b70>,
‘scalebyiv’: <function scalebyiv at 0x7fb4ac871ae8>,
‘theme’: <function theme at 0x7fb4ac871c80>}
LOCALE_PATHS
LOGGING
{‘disable_existing_loggers’: False,
‘filters’: {‘require_debug_true’: {‘()’: ‘django.utils.log.RequireDebugTrue’}},
‘formatters’: {‘simple’: {‘format’: ‘%(levelname)s %(message)s’},
‘verbose’: {‘format’: '%(levelname)s %(asctime)s %(module)s ’
‘%(process)d %(thread)d %(message)s’}},
‘handlers’: {‘console’: {‘class’: ‘logging.StreamHandler’,
‘formatter’: ‘simple’,
‘level’: ‘INFO’}},
‘loggers’: {‘app.logger’: {‘handlers’: [‘console’], ‘level’: ‘INFO’},
‘apscheduler.executors.default’: {‘handlers’: [‘console’],
‘level’: ‘WARNING’},
‘django’: {‘handlers’: [‘console’],
‘level’: ‘WARNING’,
‘propagate’: True}},
‘version’: 1}
LOGGING_CONFIG
‘logging.config.dictConfig’
LOGIN_REDIRECT_URL
‘/dashboard/’
LOGIN_URL
‘/login/’
LOGOUT_REDIRECT_URL
None
MANAGERS
MEDIA_ROOT
‘/webodm/app/media’
MEDIA_URL
MESSAGE_STORAGE
‘django.contrib.messages.storage.cookie.CookieStorage’
MESSAGE_TAGS
{40: ‘danger’}
MIDDLEWARE
[‘corsheaders.middleware.CorsMiddleware’,
‘django.middleware.security.SecurityMiddleware’,
‘django.contrib.sessions.middleware.SessionMiddleware’,
‘django.middleware.common.CommonMiddleware’,
‘django.middleware.csrf.CsrfViewMiddleware’,
‘django.contrib.auth.middleware.AuthenticationMiddleware’,
‘django.contrib.messages.middleware.MessageMiddleware’,
‘django.middleware.locale.LocaleMiddleware’]
MIDDLEWARE_CLASSES
[‘django.middleware.common.CommonMiddleware’,
‘django.middleware.csrf.CsrfViewMiddleware’]
MIGRATION_MODULES
MONTH_DAY_FORMAT
‘F j’
NUMBER_GROUPING
0
PASSWORD_HASHERS
PASSWORD_RESET_TIMEOUT_DAYS
PREPEND_WWW
False
REST_FRAMEWORK
{‘DEFAULT_AUTHENTICATION_CLASSES’: (‘rest_framework.authentication.SessionAuthentication’,
‘rest_framework.authentication.BasicAuthentication’,
‘rest_framework_jwt.authentication.JSONWebTokenAuthentication’,
‘app.api.authentication.JSONWebTokenAuthenticationQS’),
‘DEFAULT_FILTER_BACKENDS’: [‘rest_framework.filters.DjangoObjectPermissionsFilter’,
‘rest_framework.filters.DjangoFilterBackend’,
‘rest_framework.filters.OrderingFilter’],
‘DEFAULT_PERMISSION_CLASSES’: [‘app.permissions.GuardianObjectPermissions’],
‘PAGE_SIZE’: 10}
ROOT_URLCONF
‘webodm.urls’
SECRET_KEY
SECURE_BROWSER_XSS_FILTER
False
SECURE_CONTENT_TYPE_NOSNIFF
False
SECURE_HSTS_INCLUDE_SUBDOMAINS
False
SECURE_HSTS_PRELOAD
False
SECURE_HSTS_SECONDS
0
SECURE_PROXY_SSL_HEADER
None
SECURE_REDIRECT_EXEMPT
SECURE_SSL_HOST
None
SECURE_SSL_REDIRECT
False
SERVER_EMAIL
SESSION_CACHE_ALIAS
‘default’
SESSION_COOKIE_AGE
1209600
SESSION_COOKIE_DOMAIN
None
SESSION_COOKIE_HTTPONLY
True
SESSION_COOKIE_NAME
‘sessionid’
SESSION_COOKIE_PATH
SESSION_COOKIE_SECURE
False
SESSION_ENGINE
‘django.contrib.sessions.backends.db’
SESSION_EXPIRE_AT_BROWSER_CLOSE
False
SESSION_FILE_PATH
None
SESSION_SAVE_EVERY_REQUEST
False
SESSION_SERIALIZER
‘django.contrib.sessions.serializers.JSONSerializer’
SETTINGS_MODULE
‘webodm.settings’
SHORT_DATETIME_FORMAT
‘m/d/Y P’
SHORT_DATE_FORMAT
‘m/d/Y’
SIGNING_BACKEND
‘django.core.signing.TimestampSigner’
SILENCED_SYSTEM_CHECKS
STATICFILES_DIRS
[‘/webodm/app/static’]
STATICFILES_FINDERS
[‘django.contrib.staticfiles.finders.FileSystemFinder’,
‘django.contrib.staticfiles.finders.AppDirectoriesFinder’,
‘compressor.finders.CompressorFinder’]
STATICFILES_STORAGE
‘django.contrib.staticfiles.storage.StaticFilesStorage’
STATIC_ROOT
STATIC_URL
‘/static/’
TEMPLATES
[{‘APP_DIRS’: True,
‘BACKEND’: ‘django.template.backends.django.DjangoTemplates’,
‘DIRS’: [‘/webodm/app/templates’, ‘/webodm/app/templates/app’],
‘OPTIONS’: {‘context_processors’: [‘django.template.context_processors.debug’,
‘django.template.context_processors.request’,
‘django.contrib.auth.context_processors.auth’,
‘django.contrib.messages.context_processors.messages’,
‘app.contexts.settings.load’]}}]
TESTING
False
TEST_NON_SERIALIZED_APPS
TEST_RUNNER
‘django.test.runner.DiscoverRunner’
THOUSAND_SEPARATOR
TIME_FORMAT
‘P’
TIME_INPUT_FORMATS
[‘%H:%M:%S’, ‘%H:%M:%S.%f’, ‘%H:%M’]
TIME_ZONE
‘Etc/UTC’
USE_ETAGS
False
USE_I18N
True
USE_L10N
True
USE_THOUSAND_SEPARATOR
False
USE_TZ
True
USE_X_FORWARDED_HOST
False
USE_X_FORWARDED_PORT
False
WEBPACK_LOADER
{‘DEFAULT’: {‘BUNDLE_DIR_NAME’: ‘app/bundles/’,
‘STATS_FILE’: ‘/webodm/webpack-stats.json’}}
WSGI_APPLICATION
‘webodm.wsgi.application’
X_FRAME_OPTIONS
‘SAMEORIGIN’
YEAR_MONTH_FORMAT
‘F Y’
You’re seeing this error because you have DEBUG = True in your Django settings file. Change that to False, and Django will display a standard page generated by the handler for this status code.
