a few days ago WebODM started taking way longer to process a set.
I checked by rerunning a set that used to take an hour and it took 11 to process. I reinstalled my entire system POP os from fresh install. It is still taking an eternity. Please help was there an update to webodm or docker?
Both softwares are continually updating, so quite likely there were updates.
On our end, we made changes back in WebODM 3.x from 2.x that greatly increase the quality of reconstruction, but might make processing take longer on memory-constrained systems.
You can try using --skip-pc-geometric
to see if it behaves closer to what you’re used to.
sry for this but ive always used the web version
are you saying that ii should run ./webodm.sh --skip-pc-geometric start
64.0 GiB
12th Gen Intel® Core™ i7-1260P × 16
Mesa Intel® Graphics (ADL GT2)
1.0 TB SSD bty
Can i revert to the 2.X version?
You can add the parameters when editing the Task options. No need to use the terminal.
You are free to modify your docker compose file to pull an older image, but it is an unsupported configuration.
I tried the flag and it seems to be the same.
I’m currently 2 hrs in to a dataset with only 141 images its still the matching pprocess.
I’m includeing my system specs.
system Darter Pro
/0 bus Darter Pro
/0/0 memory 1MiB BIOS
/0/4 processor 12th Gen Intel(R) Core™ i7-1260P
/0/4/6 memory 256KiB L1 cache
/0/4/7 memory 2560KiB L2 cache
/0/4/8 memory 18MiB L3 cache
/0/5 memory 384KiB L1 cache
/0/9 memory 64GiB System Memory
/0/9/0 memory 32GiB SODIMM DDR4 Synchronous 3200 MHz (0.3 ns)
/0/9/1 memory 32GiB SODIMM DDR4 Synchronous 3200 MHz (0.3 ns)
/0/100 bridge Intel Corporation
/0/100/2 /dev/fb0 display Alder Lake-P Integrated Graphics Controller
/0/100/6 bridge 12th Gen Core Processor PCI Express x4 Controller #0
/0/100/6/0 /dev/nvme0 storage Samsung SSD 980 PRO 1TB
/0/100/6/0/0 hwmon3 disk NVMe disk
/0/100/6/0/2 /dev/ng0n1 disk NVMe disk
/0/100/6/0/1 /dev/nvme0n1 disk 1TB NVMe disk
/0/100/6/0/1/1 volume 511MiB Windows FAT volume
/0/100/6/0/1/2 /dev/nvme0n1p2 volume 4095MiB Windows FAT volume
/0/100/6/0/1/3 /dev/nvme0n1p3 volume 923GiB EXT4 volume
/0/100/6/0/1/4 /dev/nvme0n1p4 volume 4095MiB Linux swap volume
/0/100/7 bridge Alder Lake-P Thunderbolt 4 PCI Express Root Port #0
/0/100/a generic Platform Monitoring Technology
/0/100/d bus Alder Lake-P Thunderbolt 4 USB Controller
/0/100/d/0 usb1 bus xHCI Host Controller
/0/100/d/1 usb2 bus xHCI Host Controller
/0/100/d.2 bus Alder Lake-P Thunderbolt 4 NHI #0
/0/100/14 bus Alder Lake PCH USB 3.2 xHCI Host Controller
/0/100/14/0 usb3 bus xHCI Host Controller
/0/100/14/0/1 bus USB2.0 Hub
/0/100/14/0/1/2 input24 input PixArt USB Optical Mouse
/0/100/14/0/1/3 input25 input SIGMACHIP USB Keyboard System Control
/0/100/14/0/7 input12 multimedia Chicony USB2.0 Camera: Chicony
/0/100/14/0/a communication AX201 Bluetooth
/0/100/14/1 usb4 bus xHCI Host Controller
/0/100/14.2 memory RAM memory
/0/100/14.3 wlp0s20f3 network Alder Lake-P PCH CNVi WiFi
/0/100/15 bus Alder Lake PCH Serial IO I2C Controller #0
/0/100/15.1 bus Alder Lake PCH Serial IO I2C Controller #1
/0/100/16 communication Alder Lake PCH HECI Controller
/0/100/1c bridge Intel Corporation
/0/100/1c/0 mmc0 bus SD/MMC Card Reader Controller
/0/100/1c/0/1 /dev/mmcblk0 disk 62GB SD
/0/100/1c/0/1/1 /dev/mmcblk0p1 volume 58GiB Windows FAT volume
/0/100/1c.7 bridge Alder Lake PCH-P PCI Express Root Port #9
/0/100/1c.7/0 enp46s0 network RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
/0/100/1f bridge Alder Lake PCH eSPI Controller
/0/100/1f/0 system PnP device PNP0c02
/0/100/1f/1 system PnP device PNP0103
/0/100/1f/2 system PnP device PNP0c02
/0/100/1f/3 system PnP device PNP0b00
/0/100/1f/4 input PnP device PNP0303
/0/100/1f/5 input PnP device PNP0f13
/0/100/1f.3 card0 multimedia Alder Lake PCH-P High Definition Audio Controller
/0/100/1f.3/0 input16 input HDA Intel PCH Front Headphone
/0/100/1f.3/1 input17 input HDA Intel PCH HDMI/DP,pcm=3
/0/100/1f.3/2 input18 input HDA Intel PCH HDMI/DP,pcm=7
/0/100/1f.3/3 input19 input HDA Intel PCH HDMI/DP,pcm=8
/0/100/1f.3/4 input20 input HDA Intel PCH HDMI/DP,pcm=9
/0/100/1f.4 bus Alder Lake PCH-P SMBus Host Controller
/0/100/1f.5 bus Alder Lake-P PCH SPI Controller
/1 input0 input Power Button
/2 input1 input Sleep Button
/3 input10 input Video Bus
/4 input11 input Intel HID events
/5 input13 input ELAN0412:00 04F3:3240 Mouse
/6 input15 input ELAN0412:00 04F3:3240 Touchpad
/7 input2 input Lid Switch
/8 input3 input Power Button
/9 input4 input AT Translated Set 2 keyboard
/a input6 input System76 ACPI Hotkeys
Do all you images have geographic data included or is the log full of messages which include references to WORDS?
It’s all referencing words
Then the issue is unlikely to be an update but a data problem. Make sure you have geographic data in the tags of your images. Check the first 100 lines of the log: you’ll see warnings that tell you which images are missing the tags.
I’m processing the same data set i procesed already once before
what took an hours now takes all day
I’ve been looking at the system monitor and i noticed that ionly 2 cores seem to be doing anything during the matching process. I don’t know what it was utilizing before but maybe thatt has something to do with it? the other thing is that the options for processeing are missing many ofthe default configs that sed to be there. Before the system crash there were other options like multiband and high resolution buildings. Maybe that gives us a clue
This is common for matching and probably not a change in behavior. I’ve got directions on the forum for running a specific older version. I’d link to it directly, but I’m on my phone at the moment, so the search will need to be yours. But you can use those directions to do a direct comparison between versions.
But first things first: can you show the first few lines of the logs (maybe 2-300) from the fast version and the current slow running version? That would help us discern what the issue might be.
We’ve streamlined our default Task Presets, so this isn’t something to be concerned over.
i do not have the fast version anymore it was on the same computer that i reloaded. but here are the first 400 from the current slow matching task
[INFO] Fast orthophoto is turned on, automatically setting --skip-3dmodel
[INFO] Initializing ODM 3.0.5 - Sat Mar 11 19:08:23 2023
[INFO] ==============
[INFO] 3d_tiles: False
[INFO] align: None
[INFO] auto_boundary: True
[INFO] auto_boundary_distance: 0
[INFO] bg_removal: False
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] fast_orthophoto: True
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: /var/www/data/72c57a04-14cc-4a39-aae1-1cfc56552b0b/gcp/gcp_file_1678398606518.txt
[INFO] geo: None
[INFO] gltf: True
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_neighbors: 0
[INFO] matcher_type: flann
[INFO] max_concurrency: 16
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] name: 72c57a04-14cc-4a39-aae1-1cfc56552b0b
[INFO] no_gpu: False
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_copc: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_skip_geometric: False
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] rolling_shutter: False
[INFO] skip_3dmodel: True
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sky_removal: False
[INFO] sm_cluster: None
[INFO] sm_no_align: False
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] texturing_single_material: False
[INFO] tiles: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] video_limit: 500
[INFO] video_resolution: 4000
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/72c57a04-14cc-4a39-aae1-1cfc56552b0b/images
[INFO] Found video files (8), extracting frames
[INFO] Processing video: /var/www/data/72c57a04-14cc-4a39-aae1-1cfc56552b0b/images/20230308-143158.mp4
[INFO] VideoInfo(total_frames=829, frame_rate=30.00750187546887, basename=‘20230308-143158’)
[INFO] Use pseudo start time: 2023-03-11 19:08:07.226859
[INFO] Preprocessing for black frame checker… this might take a bit
[INFO] Calculated luminance_range_size is 255
[INFO] Calculated luminance_minimum_value is 0
[INFO] Calculated absolute_threshold is 76.5
[20230308-143158.mp4][ 1%] Processing frame 9/829:
[20230308-143158.mp4][ 2%] Processing frame 17/829:
[20230308-143158.mp4][ 3%] Processing frame 25/829:
[20230308-143158.mp4][ 4%] Processing frame 34/829:
[20230308-143158.mp4][ 5%] Processing frame 42/829:
[20230308-143158.mp4][ 6%] Processing frame 50/829:
[20230308-143158.mp4][ 7%] Processing frame 59/829:
[20230308-143158.mp4][ 8%] Processing frame 67/829:
[20230308-143158.mp4][ 9%] Processing frame 75/829:
[20230308-143158.mp4][ 10%] Processing frame 83/829:
[20230308-143158.mp4][ 11%] Processing frame 92/829:
[20230308-143158.mp4][ 12%] Processing frame 100/829:
[20230308-143158.mp4][ 13%] Processing frame 108/829:
[20230308-143158.mp4][ 14%] Processing frame 117/829:
[20230308-143158.mp4][ 15%] Processing frame 125/829:
[20230308-143158.mp4][ 16%] Processing frame 133/829:
[20230308-143158.mp4][ 17%] Processing frame 141/829:
[20230308-143158.mp4][ 18%] Processing frame 150/829:
[20230308-143158.mp4][ 19%] Processing frame 158/829:
[20230308-143158.mp4][ 20%] Processing frame 166/829:
[20230308-143158.mp4][ 21%] Processing frame 175/829:
[20230308-143158.mp4][ 22%] Processing frame 183/829:
[20230308-143158.mp4][ 23%] Processing frame 191/829:
[20230308-143158.mp4][ 24%] Processing frame 199/829:
[20230308-143158.mp4][ 25%] Processing frame 208/829:
[20230308-143158.mp4][ 26%] Processing frame 216/829:
[20230308-143158.mp4][ 27%] Processing frame 224/829:
[20230308-143158.mp4][ 28%] Processing frame 233/829:
[20230308-143158.mp4][ 29%] Processing frame 241/829:
[20230308-143158.mp4][ 30%] Processing frame 249/829:
[20230308-143158.mp4][ 31%] Processing frame 257/829:
[20230308-143158.mp4][ 32%] Processing frame 266/829:
[20230308-143158.mp4][ 33%] Processing frame 274/829:
[20230308-143158.mp4][ 34%] Processing frame 282/829:
[20230308-143158.mp4][ 35%] Processing frame 291/829:
[20230308-143158.mp4][ 36%] Processing frame 299/829:
[20230308-143158.mp4][ 37%] Processing frame 307/829:
[20230308-143158.mp4][ 38%] Processing frame 316/829:
[20230308-143158.mp4][ 39%] Processing frame 324/829:
[20230308-143158.mp4][ 40%] Processing frame 332/829:
[20230308-143158.mp4][ 41%] Processing frame 340/829:
[20230308-143158.mp4][ 42%] Processing frame 349/829:
[20230308-143158.mp4][ 43%] Processing frame 357/829:
[20230308-143158.mp4][ 44%] Processing frame 365/829:
[20230308-143158.mp4][ 45%] Processing frame 374/829:
[20230308-143158.mp4][ 46%] Processing frame 382/829:
[20230308-143158.mp4][ 47%] Processing frame 390/829:
[20230308-143158.mp4][ 48%] Processing frame 398/829:
[20230308-143158.mp4][ 49%] Processing frame 407/829:
[20230308-143158.mp4][ 50%] Processing frame 415/829:
[20230308-143158.mp4][ 51%] Processing frame 423/829:
[20230308-143158.mp4][ 52%] Processing frame 432/829:
[20230308-143158.mp4][ 53%] Processing frame 440/829:
[20230308-143158.mp4][ 54%] Processing frame 448/829:
[20230308-143158.mp4][ 55%] Processing frame 456/829:
[20230308-143158.mp4][ 56%] Processing frame 465/829:
[20230308-143158.mp4][ 57%] Processing frame 473/829:
[20230308-143158.mp4][ 58%] Processing frame 481/829:
[20230308-143158.mp4][ 59%] Processing frame 490/829:
[20230308-143158.mp4][ 60%] Processing frame 498/829:
[20230308-143158.mp4][ 61%] Processing frame 506/829:
[20230308-143158.mp4][ 62%] Processing frame 514/829:
[20230308-143158.mp4][ 63%] Processing frame 523/829:
[20230308-143158.mp4][ 64%] Processing frame 531/829:
[20230308-143158.mp4][ 65%] Processing frame 539/829:
[20230308-143158.mp4][ 66%] Processing frame 548/829:
[20230308-143158.mp4][ 67%] Processing frame 556/829:
[20230308-143158.mp4][ 68%] Processing frame 564/829:
[20230308-143158.mp4][ 69%] Processing frame 573/829:
[20230308-143158.mp4][ 70%] Processing frame 581/829:
[20230308-143158.mp4][ 71%] Processing frame 589/829:
[20230308-143158.mp4][ 72%] Processing frame 597/829:
[20230308-143158.mp4][ 73%] Processing frame 606/829:
[20230308-143158.mp4][ 74%] Processing frame 614/829:
[20230308-143158.mp4][ 75%] Processing frame 622/829:
[20230308-143158.mp4][ 76%] Processing frame 631/829:
[20230308-143158.mp4][ 77%] Processing frame 639/829:
[20230308-143158.mp4][ 78%] Processing frame 647/829:
[20230308-143158.mp4][ 79%] Processing frame 655/829:
[20230308-143158.mp4][ 80%] Processing frame 664/829:
[20230308-143158.mp4][ 81%] Processing frame 672/829:
[20230308-143158.mp4][ 82%] Processing frame 680/829:
[20230308-143158.mp4][ 83%] Processing frame 689/829:
[20230308-143158.mp4][ 84%] Processing frame 697/829:
[20230308-143158.mp4][ 85%] Processing frame 705/829:
[20230308-143158.mp4][ 86%] Processing frame 713/829:
[20230308-143158.mp4][ 87%] Processing frame 722/829:
[20230308-143158.mp4][ 88%] Processing frame 730/829:
[20230308-143158.mp4][ 89%] Processing frame 738/829:
[20230308-143158.mp4][ 90%] Processing frame 747/829:
[20230308-143158.mp4][ 91%] Processing frame 755/829:
[20230308-143158.mp4][ 92%] Processing frame 763/829:
[20230308-143158.mp4][ 93%] Processing frame 771/829:
[20230308-143158.mp4][ 94%] Processing frame 780/829:
[20230308-143158.mp4][ 95%] Processing frame 788/829:
[20230308-143158.mp4][ 96%] Processing frame 796/829:
[20230308-143158.mp4][ 97%] Processing frame 805/829:
[20230308-143158.mp4][ 98%] Processing frame 813/829:
[20230308-143158.mp4][ 99%] Processing frame 821/829:
[20230308-143158.mp4][100%] Processing frame 829/829:
[INFO] Processing video: /var/www/data/72c57a04-14cc-4a39-aae1-1cfc56552b0b/images/20230308-143243.mp4
[INFO] VideoInfo(total_frames=915, frame_rate=30.0, basename=‘20230308-143243’)
[INFO] Use pseudo start time: 2023-03-11 19:08:37.726859
[INFO] Preprocessing time: 9.97s
[20230308-143243.mp4][ 1%] Processing frame 10/915:
[20230308-143243.mp4][ 2%] Processing frame 19/915:
[20230308-143243.mp4][ 3%] Processing frame 28/915:
[20230308-143243.mp4][ 4%] Processing frame 37/915:
[20230308-143243.mp4][ 5%] Processing frame 46/915:
[20230308-143243.mp4][ 6%] Processing frame 55/915:
[20230308-143243.mp4][ 7%] Processing frame 65/915:
[20230308-143243.mp4][ 8%] Processing frame 74/915:
[20230308-143243.mp4][ 9%] Processing frame 83/915:
[20230308-143243.mp4][ 10%] Processing frame 92/915:
[20230308-143243.mp4][ 11%] Processing frame 101/915:
[20230308-143243.mp4][ 12%] Processing frame 110/915:
[20230308-143243.mp4][ 13%] Processing frame 119/915:
[20230308-143243.mp4][ 14%] Processing frame 129/915:
[20230308-143243.mp4][ 15%] Processing frame 138/915:
[20230308-143243.mp4][ 16%] Processing frame 147/915:
[20230308-143243.mp4][ 17%] Processing frame 156/915:
[20230308-143243.mp4][ 18%] Processing frame 165/915:
[20230308-143243.mp4][ 19%] Processing frame 174/915:
[20230308-143243.mp4][ 20%] Processing frame 183/915:
[20230308-143243.mp4][ 21%] Processing frame 193/915:
[20230308-143243.mp4][ 22%] Processing frame 202/915:
[20230308-143243.mp4][ 23%] Processing frame 211/915:
[20230308-143243.mp4][ 24%] Processing frame 220/915:
[20230308-143243.mp4][ 25%] Processing frame 229/915:
[20230308-143243.mp4][ 26%] Processing frame 238/915:
[20230308-143243.mp4][ 27%] Processing frame 248/915:
[20230308-143243.mp4][ 28%] Processing frame 257/915:
[20230308-143243.mp4][ 29%] Processing frame 266/915:
[20230308-143243.mp4][ 30%] Processing frame 275/915:
[20230308-143243.mp4][ 31%] Processing frame 284/915:
[20230308-143243.mp4][ 32%] Processing frame 293/915:
[20230308-143243.mp4][ 33%] Processing frame 302/915:
[20230308-143243.mp4][ 34%] Processing frame 312/915:
[20230308-143243.mp4][ 35%] Processing frame 321/915:
[20230308-143243.mp4][ 36%] Processing frame 330/915:
[20230308-143243.mp4][ 37%] Processing frame 339/915:
[20230308-143243.mp4][ 38%] Processing frame 348/915:
[20230308-143243.mp4][ 39%] Processing frame 357/915:
[20230308-143243.mp4][ 40%] Processing frame 366/915:
[20230308-143243.mp4][ 41%] Processing frame 376/915:
[20230308-143243.mp4][ 42%] Processing frame 385/915:
[20230308-143243.mp4][ 43%] Processing frame 394/915:
[20230308-143243.mp4][ 44%] Processing frame 403/915:
[20230308-143243.mp4][ 45%] Processing frame 412/915:
[20230308-143243.mp4][ 46%] Processing frame 421/915:
[20230308-143243.mp4][ 47%] Processing frame 431/915:
[20230308-143243.mp4][ 48%] Processing frame 440/915:
[20230308-143243.mp4][ 49%] Processing frame 449/915:
[20230308-143243.mp4][ 50%] Processing frame 458/915:
[20230308-143243.mp4][ 51%] Processing frame 467/915:
[20230308-143243.mp4][ 52%] Processing frame 476/915:
[20230308-143243.mp4][ 53%] Processing frame 485/915:
[20230308-143243.mp4][ 54%] Processing frame 495/915:
[20230308-143243.mp4][ 55%] Processing frame 504/915:
[20230308-143243.mp4][ 56%] Processing frame 513/915:
[20230308-143243.mp4][ 57%] Processing frame 522/915:
[20230308-143243.mp4][ 58%] Processing frame 531/915:
[20230308-143243.mp4][ 59%] Processing frame 540/915:
[20230308-143243.mp4][ 60%] Processing frame 549/915:
[20230308-143243.mp4][ 61%] Processing frame 559/915:
[20230308-143243.mp4][ 62%] Processing frame 568/915:
[20230308-143243.mp4][ 63%] Processing frame 577/915:
[20230308-143243.mp4][ 64%] Processing frame 586/915:
[20230308-143243.mp4][ 65%] Processing frame 595/915:
[20230308-143243.mp4][ 66%] Processing frame 604/915:
[20230308-143243.mp4][ 67%] Processing frame 614/915:
[20230308-143243.mp4][ 68%] Processing frame 623/915:
[20230308-143243.mp4][ 69%] Processing frame 632/915:
[20230308-143243.mp4][ 70%] Processing frame 641/915:
[20230308-143243.mp4][ 71%] Processing frame 650/915:
[20230308-143243.mp4][ 72%] Processing frame 659/915:
[20230308-143243.mp4][ 73%] Processing frame 668/915:
[20230308-143243.mp4][ 74%] Processing frame 678/915:
[20230308-143243.mp4][ 75%] Processing frame 687/915:
[20230308-143243.mp4][ 76%] Processing frame 696/915:
[20230308-143243.mp4][ 77%] Processing frame 705/915:
[20230308-143243.mp4][ 78%] Processing frame 714/915:
[20230308-143243.mp4][ 79%] Processing frame 723/915:
[20230308-143243.mp4][ 80%] Processing frame 732/915:
[20230308-143243.mp4][ 81%] Processing frame 742/915:
[20230308-143243.mp4][ 82%] Processing frame 751/915:
[20230308-143243.mp4][ 83%] Processing frame 760/915:
[20230308-143243.mp4][ 84%] Processing frame 769/915:
[20230308-143243.mp4][ 85%] Processing frame 778/915:
[20230308-143243.mp4][ 86%] Processing frame 787/915:
[20230308-143243.mp4][ 87%] Processing frame 797/915:
[20230308-143243.mp4][ 88%] Processing frame 806/915:
[20230308-143243.mp4][ 89%] Processing frame 815/915:
[20230308-143243.mp4][ 90%] Processing frame 824/915:
[20230308-143243.mp4][ 91%] Processing frame 833/915:
[20230308-143243.mp4][ 92%] Processing frame 842/915:
[20230308-143243.mp4][ 93%] Processing frame 851/915:
[20230308-143243.mp4][ 94%] Processing frame 861/915:
[20230308-143243.mp4][ 95%] Processing frame 870/915:
[20230308-143243.mp4][ 96%] Processing frame 879/915:
[20230308-143243.mp4][ 97%] Processing frame 888/915:
[20230308-143243.mp4][ 98%] Processing frame 897/915:
[20230308-143243.mp4][ 99%] Processing frame 906/915:
[20230308-143243.mp4][100%] Processing frame 915/915:
[INFO] Processing video: /var/www/data/72c57a04-14cc-4a39-aae1-1cfc56552b0b/images/20230308-142923.mp4
[INFO] VideoInfo(total_frames=970, frame_rate=30.00750187546887, basename=‘20230308-142923’)
[INFO] Use pseudo start time: 2023-03-11 19:09:10.052109
[INFO] Preprocessing time: 10.23s
We didn’t used to support processing video until very recently.
Take the mp4 files out of your Task upload and try again.
I guarentee thats it but im rerunning
I pull my frames from MP4 and it didn’t ued to added them when i selected all
Ill keep you posted
I just wanted to make it known that by removing the MP4 files processing dropped down to 22 minutes. Thank you so much for your help. I also am very interested in investigating the possibilities of using video directly now that i know its an option
Glad to hear that you are doing well!
Video can be convenient, but it is also often underwhelming due to lower resolution, aggressive compression, and sometimes more severe Rolling Shutter Distortion.
If your platform supports flight planning, I personally would always choose images over video
i agree but for now im using a cheap off-brand drone so video is all ive got
