Processing node offline issue
Hi Friends,
I love WebODM, using it from long time
I installed it on a new Windows machine, installation happened successfully. However, Processing node goes offline (node-odm-1 seems to be offline.) whenever I start WebODM fresh.
I found that, by manfully changing the hostname to ip address, this can be solved. Is there anything I can do to fix permanently
processing_node processing_node2
Thanks in Advance !!!
Do you have more information about your setup?
WebODM for Windows native should be using a localhost/loopback address for the node-odm-1 processing node, as it should default to processing on the same machine it is installed on.
Thanks, which information about setup is need?
I did not understood how to solve
docker windows
Did you purchase WebODM for Windows via UAV4Geo, or are you just running it on your own via Docker?
I am running WebODM via Docker
Ah, okay. Do you have a firewall, or perhaps any other modifications to your hosts file from something like SpyBot perhaps?
Also, if you purchased a license, reach out to hello@uav4geo.com.
ok. thank you. I will check that out
