Processing keep running
Hi All,
Thank you in advance for your help.
I encountered an issue while processing images in WebODM Lightning. I run WebODM in Windows via Desktop docker. The issue is that the status bar “running” keeps running after the task is completed, I enabled a notification for task completion so I receive an e-mail with a link to download all assets.
Anyone experiences a similar problem and how you fix it.
Bounchanh
I have experienced this as well and unfortunately time seems to be the solution. Despite getting an email with the link to download the assets saying the job has completed the WebODM Lightning software says it’s still running. Sometimes for a long time afterwards. Eventually it will stop and then you will be able to look at the results in the Lightning viewer.
Piero is looking into some things that will likely improve, if not outright solve, this behavior:
