my office is using WebODM for the first time. I am trying to stitch 9 photos with overlap. The software has picked up the location correctly from the pictures but sadly comes up with this error message:
[ERROR] The program exited with a strange error code. Please report it at https://community.opendronemap.org
Whis is a shame as it seems to get reasonably far through the process:
[INFO] Initializing ODM - Wed Dec 01 12:13:51 2021
[INFO] ==============
[INFO] auto_boundary: False
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: True
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 4
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: 80dfce1e-a3c3-4a71-82f9-723ec183f8d2
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: C:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\images
[INFO] Loading 2 images
[INFO] Wrote images database: C:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\images.json
[INFO] Found 2 usable images
[INFO] Parsing SRS header: WGS84 UTM 31N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Writing exif overrides
[INFO] Maximum photo dimensions: 2048px
[INFO] Photo dimensions for feature extraction: 1024px
[INFO] [âuse_exif_size: noâ, âflann_algorithm: KDTREEâ, âfeature_process_size: 1024â, âfeature_min_frames: 8000â, âprocesses: 4â, âmatching_gps_neighbors: 8â, âmatching_gps_distance: 0â, âoptimize_camera_parameters: yesâ, âundistorted_image_format: tifâ, âbundle_outlier_filtering_type: AUTOâ, âsift_peak_threshold: 0.066â, âalign_orientation_prior: verticalâ, âtriangulation_type: ROBUSTâ, âretriangulation_ratio: 2â, âmatcher_type: FLANNâ, âfeature_type: SIFTâ, âuse_altitude_tag: yesâ, âalign_method: autoâ, âlocal_bundle_radius: 0â]
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm extract_metadata âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfmâ
2021-12-01 12:13:53,493 INFO: Extracting EXIF for DJI_0498.JPG
2021-12-01 12:13:53,536 INFO: Extracting EXIF for DJI_0499.JPG
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm detect_features âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfmâ
2021-12-01 12:13:55,078 INFO: Expecting to process 97 images.
2021-12-01 12:13:55,084 INFO: Reading data for image DJI_0498.JPG (queue-size=0
2021-12-01 12:13:55,084 INFO: Reading data for image DJI_0499.JPG (queue-size=0
2021-12-01 12:13:55,146 INFO: Finished reading images
2021-12-01 12:13:55,147 INFO: Extracting ROOT_SIFT features for image DJI_0498.JPG
2021-12-01 12:13:55,147 INFO: Extracting ROOT_SIFT features for image DJI_0499.JPG
2021-12-01 12:13:55,226 DEBUG: Computing sift with threshold 0.066
2021-12-01 12:13:55,227 DEBUG: Computing sift with threshold 0.066
2021-12-01 12:13:55,603 DEBUG: Found 669 points in 0.37563061714172363s
2021-12-01 12:13:55,604 DEBUG: Found 695 points in 0.37563061714172363s
2021-12-01 12:13:55,604 DEBUG: reducing threshold
2021-12-01 12:13:55,604 DEBUG: Computing sift with threshold 0.044000000000000004
2021-12-01 12:13:55,869 DEBUG: Found 2473 points in 0.2652900218963623s
2021-12-01 12:13:55,869 DEBUG: reducing threshold
2021-12-01 12:13:55,870 DEBUG: Computing sift with threshold 0.029333333333333336
2021-12-01 12:13:55,879 DEBUG: Found 2578 points in 0.27526378631591797s
2021-12-01 12:13:55,879 DEBUG: reducing threshold
2021-12-01 12:13:55,879 DEBUG: Computing sift with threshold 0.029333333333333336
2021-12-01 12:13:56,122 DEBUG: Found 4484 points in 0.2513270378112793s
2021-12-01 12:13:56,122 DEBUG: reducing threshold
2021-12-01 12:13:56,123 DEBUG: Computing sift with threshold 0.01955555555555556
2021-12-01 12:13:56,133 DEBUG: Found 4668 points in 0.25332093238830566s
2021-12-01 12:13:56,133 DEBUG: reducing threshold
2021-12-01 12:13:56,133 DEBUG: Computing sift with threshold 0.01955555555555556
2021-12-01 12:13:56,344 DEBUG: Found 5698 points in 0.22141027450561523s
2021-12-01 12:13:56,344 DEBUG: reducing threshold
2021-12-01 12:13:56,344 DEBUG: Computing sift with threshold 0.01303703703703704
2021-12-01 12:13:56,351 DEBUG: Found 6201 points in 0.21841835975646973s
2021-12-01 12:13:56,351 DEBUG: reducing threshold
2021-12-01 12:13:56,351 DEBUG: Computing sift with threshold 0.01303703703703704
2021-12-01 12:13:56,561 DEBUG: Found 6688 points in 0.21741867065429688s
2021-12-01 12:13:56,561 DEBUG: reducing threshold
2021-12-01 12:13:56,561 DEBUG: Computing sift with threshold 0.00869135802469136
2021-12-01 12:13:56,570 DEBUG: Found 7217 points in 0.21941494941711426s
2021-12-01 12:13:56,570 DEBUG: reducing threshold
2021-12-01 12:13:56,570 DEBUG: Computing sift with threshold 0.00869135802469136
2021-12-01 12:13:56,800 DEBUG: Found 7763 points in 0.23836159706115723s
2021-12-01 12:13:56,800 DEBUG: reducing threshold
2021-12-01 12:13:56,800 DEBUG: Computing sift with threshold 0.005794238683127573
2021-12-01 12:13:56,814 DEBUG: Found 8171 points in 0.2433452606201172s
2021-12-01 12:13:56,815 DEBUG: done
2021-12-01 12:13:57,065 DEBUG: Found 8723 points in 0.2652907371520996s
2021-12-01 12:13:57,065 DEBUG: done
2021-12-01 12:13:57,219 DEBUG: No segmentation for DJI_0499.JPG, no features masked.
2021-12-01 12:13:57,381 DEBUG: No segmentation for DJI_0498.JPG, no features masked.
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm match_features âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfmâ
2021-12-01 12:13:59,138 INFO: Matching 1 image pairs
2021-12-01 12:13:59,139 INFO: Computing pair matching with 3 processes
2021-12-01 12:13:59,288 DEBUG: No segmentation for DJI_0498.JPG, no features masked.
2021-12-01 12:13:59,321 DEBUG: No segmentation for DJI_0499.JPG, no features masked.
2021-12-01 12:13:59,739 DEBUG: Matching DJI_0498.JPG and DJI_0499.JPG. Matcher: FLANN (symmetric) T-desc: 0.566 T-robust: 0.032 T-total: 0.599 Matches: 1408 Robust: 1395 Success: True
2021-12-01 12:13:59,739 INFO: Matched 1 pairs (brown-brown: 1) in 0.600814 seconds (0.6008142999999999 seconds/pair).
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm create_tracks âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfmâ
2021-12-01 12:14:01,333 INFO: reading features
2021-12-01 12:14:01,402 DEBUG: Merging features onto tracks
2021-12-01 12:14:01,411 DEBUG: Good tracks: 1395
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm reconstruct âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfmâ
2021-12-01 12:14:03,027 INFO: Starting incremental reconstruction
2021-12-01 12:14:03,049 INFO: Starting reconstruction with DJI_0498.JPG and DJI_0499.JPG
2021-12-01 12:14:03,162 INFO: Two-view reconstruction inliers: 1395 / 1395
2021-12-01 12:14:03,240 INFO: Triangulated: 1395
2021-12-01 12:14:03,798 DEBUG: Ceres Solver Report: Iterations: 17, Initial cost: 1.030451e+01, Final cost: 3.226842e+00, Termination: CONVERGENCE
2021-12-01 12:14:03,845 INFO: Removed outliers: 35
2021-12-01 12:14:03,879 INFO: -------------------------------------------------------
2021-12-01 12:14:04,001 DEBUG: Ceres Solver Report: Iterations: 13, Initial cost: 9.800734e+00, Final cost: 2.764067e+00, Termination: CONVERGENCE
2021-12-01 12:14:04,045 INFO: Removed outliers: 1
2021-12-01 12:14:04,077 INFO: Reconstruction 0: 2 images, 1372 points
2021-12-01 12:14:04,077 INFO: 1 partial reconstructions in total.
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm compute_statistics --diagram_max_points 100000 âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfmâ
2021-12-01 12:14:06,856 DEBUG: locator: <matplotlib.colorbar._ColorbarAutoLocator object at 0x0000021311892970>
2021-12-01 12:14:06,857 DEBUG: Using auto colorbar locator <matplotlib.colorbar._ColorbarAutoLocator object at 0x0000021311892970> on colorbar
2021-12-01 12:14:06,857 DEBUG: Setting pcolormesh
C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\opensfm\stats.py:656: RuntimeWarning: invalid value encountered in double_scalars
c = max(0, min(1.0, 1 - (edge - lowest) / (highest - lowest)))
2021-12-01 12:14:07,558 DEBUG: locator: <matplotlib.colorbar._ColorbarAutoLocator object at 0x00000213118E9EB0>
2021-12-01 12:14:07,558 DEBUG: Using auto colorbar locator <matplotlib.colorbar._ColorbarAutoLocator object at 0x00000213118E9EB0> on colorbar
2021-12-01 12:14:07,558 DEBUG: Setting pcolormesh
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_geocoords --reconstruction --proj â+proj=utm +zone=31 +datum=WGS84 +units=m +no_defs +type=crsâ --offset-x 413234.0 --offset-y 5805895.0 âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfmâ
[INFO] Updating C:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfm\config.yaml
[INFO] undistorted_image_max_size: 2048
[INFO] Undistorting C:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfm âŚ
2021-12-01 12:14:20,689 DEBUG: Undistorting image DJI_0499.JPG
2021-12-01 12:14:20,688 DEBUG: Undistorting image DJI_0498.JPG
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_visualsfm --points âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfmâ
[INFO] Finished opensfm stage
[INFO] Running openmvs stage
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_openmvs âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfmâ
[INFO] Estimating depthmaps
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\OpenMVS\DensifyPointCloud âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfm\undistorted\openmvs\scene.mvsâ --resolution-level 3 --min-resolution 320 --max-resolution 2048 --max-threads 4 --number-views-fuse 2 -w âC:\WebODM\resources\app\apps\NodeODM\data\80dfce1e-a3c3-4a71-82f9-723ec183f8d2\opensfm\undistorted\openmvs\depthmapsâ -v 0 --geometric-iters 0
Child returned 3221225781
File âC:\WebODM\resources\app\apps\ODM\stages\odm_app.pyâ, line 94, in execute
File âC:\WebODM\resources\app\apps\ODM\opendm\types.pyâ, line 346, in run
File âC:\WebODM\resources\app\apps\ODM\opendm\types.pyâ, line 327, in run
File âC:\WebODM\resources\app\apps\ODM\stages\openmvs.pyâ, line 83, in process
system.run(â%s â%sâ %sâ % (context.omvs_densify_path,
File âC:\WebODM\resources\app\apps\ODM\opendm\system.pyâ, line 106, in run
raise SubprocessException(âChild returned {}â.format(retcode), retcode)
opendm.system.SubprocessException: Child returned 3221225781
===== Done, human-readable information to follow⌠=====
